Question about Apple iPod touch
Home button is stuck
My home button is stuck and it wont pop back out (click) like it normally does, so what can i do to fix this, can i open it? and if i can how, or is there something else i can do?
My i phone 4 get stucked at least 1 in every 45 days
if it gets stuck force reboot Hold power and home button down for 10 seconds then turn it back on. For performance regularly shutdown open apps double click the Home button. Apps pop up down the bottom, hold finger on one and they all begin to wiggle, click the X in the corner of all the open apps.
Nov 14, 2013 | Apple Iphone 4s I Phone 4 S Factory...
Acer aspire dvd wont open with eject button
Whether you use your DVD drive to install software, make backups of your personal files or watch movies, having that drive onboard makes your computer more useful and more versatile.
While DVD drives function normally most of the time, sometimes a DVD will become stuck in the drive, and the tray will refuse to open.
Knowing what steps to take to resolve the situation allows you to start enjoying the advantages of the DVD drive again.
Log on to your computer and click the "Start" button. Choose "Shut down" from the menu and then choose "Restart." Wait for the computer to restart, then press the eject button repeatedly.
Remove the DVD if the drive pops out.
Since there is no hole skip this and go to cleaning the lens.
Shine a flashlight on the DVD tray and locate the small hole near the eject button.
This is the bypass hole and it allows you to eject a DVD when it becomes stuck.
Insert an unbent paper clip into the hole and push it in until you hear the DVD begin to spin. Push the paper clip in until the drive pops out.
Remove the DVD and insert another one.
Use the bypass hole again if the new DVD becomes stuck.
If the new DVD sticks as well, you need to clean the laser lens on the DVD drive.
Insert a laser lens cleaning DVD and close the tray.
Run the laser lens cleaning program at least three or four times to make sure the lens receives a thorough cleaning.
Restart your computer and insert a DVD to test the unit.
Oct 19, 2012 | Lifetime Acer Aspire 4810TZ-4011...
Ipod home button is stuck down
iPod home buttons fail all the time. If the button feels stuck in the down position, you no longer feel that distinct "pop" then it is a design issue and should be taken to the apple store for warranty work. If the iPod is out of warranty, then there are several shops that service home buttons. If the home button still "pops" as it should, then the issue is with moisture exposure. Sweat and wet hands while using the home button allow the moisture to seep into the home button area, eventually causing a corrosion buildup that slowly deteriorates the home buttons ability to do its simple job, after repeated exposure, it just has too much corrosion and stops working. If you of warranty period, check out my home button repairs, all with a 15 month warranty against defects, best price in the industry http://www.zfixit.com/ipod-touch-repairs/ c3f42093-2937-4241-8c7c-3b7ddbc184e5.jpg
Mar 24, 2012 | Apple iPod touch 3rd Generation MP3 Player
Help please tell how to exit recovery mode
How to Fix an iPod Touch Stuck in Recovery Mode With a Free Program
An iPod Touch's "Recovery Mode" is for alleviating major operating system issues. Recovery Mode rolls back your iPod's operating system, stripping problematic updates and downloads from the unit. The goal of this total system recovery is to revert the iPod to a stable, usable version. Before you use Recovery Mode, exhaust other troubleshooting methods. In some cases, Recovery Mode is triggered automatically after a failed system update or system restore. When it goes into Recovery Mode automatically, you cannot use your iPod until you complete the recovery process. You can get your iPod Touch out of Recovery Mode using Apple's free iTunes software.
Things You'll Need
-Apple iTunes-USB cable
Instructions
1 Turn on your computer and open iTunes. If you are prompted to download any new iTunes updates, install the updates before proceeding.
2 Plug an iPod USB cable into your computer. Do not plug the other end into your iPod Touch yet.
3 Turn off your iPod Touch. If the iPod Touch is already shut down, skip this step.
4 Press and hold the Home button on your iPod Touch, and plug the other end of the USB cable into your iPod Touch.
5 Release the Home button after you see a white USB icon and the iTunes logo appear on your iPod Touch's screen. At this time, a pop-up should appear on your computer screen, explaining that the software has detected an iPod in Recovery Mode.
6 Click "OK."
7 Click on the iPod Touch from underneath the "Devices" heading on the left-hand side of your screen.
8 Click on the "Home" tab, and then click "Restore." Once it's restored, your iPod Touch goes out of Recovery Mode and you can start using it again. The restoration process takes a few minutes. Do not disconnect your iPod Touch until a prompt appears, letting you know the system restored successfully.
Dec 24, 2011 | Apple iPhone Audio Players & Recorders
My ipod touch is stuck on a screen that says "ipod is disabled, try again in 5,785,421 mintues"
Connect your iPod Touch to your computer. Turn your iPod Touch off (hold down the top button and slide the red off slider). Then hold down the top button and the home button for ten seconds then let go of the top button while still holding the home button and KEEP holding it for up to 30 seconds. If it doesn't work the first time, try it again - iTunes should pop up and say that it sees an iPod Touch in restore mode. Click restore and you'll be able to get it back up...
May 04, 2011 | Apple iPod touch
I i AM UNABLE TO LOOK UP ANY THING BECAUSE FACEBOK IS IN MY WAYto get rid of the fACEBOOK SCREEN HOOW DO I D THIS
Hi. First, open your browser.
I'm guessing by your statement that somehow facebook has turned into your home page, so here is how to fix that.
These instructions are for Firefox, Internet explorer instructions are further down.
Ok, now, leave the first page open for now, and open a new tab.
Immediately click the stop button, so that no page opens.
Next in the address bar type: www.google.com and press enter.
This should give you the google website.
Next, Left click on the little g logo that is at the beginning of the address bar, and hold down the mouse button, and drag it to on top of the browsers home button.
It should pop up a box that either asks, or states, that google is being added as your home page.
This is the way to do it for foxfire.
Now, here is how to change your homepage in internet explorer.
You can do this with or without a browser being open.
With is easier, just from instruction standpoint, but after a couple of steps, it is the same for IE
Open IE browser
click the tools tab
click internet options
OK, this will pop up the internet properties box
Change the address of the homepage from facebook.com to google.com
Delete the facebook entry on the homepage list
click apply
This should take care of the problem, but before you close the internet property box click delete history, and have the system delete your browsing history.
It may make a few webpages load a little slower, but it could be a cookie is what is making facebook always be on top.
Delete your browsing history in firefox as well.
Then reboot, and try opening a browser.
It should work normal for you again.
Feb 06, 2011 | JVC AV-32120 32" TV
I phone wont chage from lap top or wall charger
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 05, 2011 | Apple iPhone Smartphone
Push start button wont start dryer
This could be the non resettable thermal fuse has popped, or the door switch is not working. Open the door and press on the door switch until it clicks and push start to see if it works. If it clicks and still no start, then the thermal fuse needs replaced. UNPLUG the dryer, remove the back and you will see the white thermal that looks like a regular thermostat with 2 wires on it. It is located on the air plenum. There could be 2 depending on the exact model, but normally only one white one. These thermals usually pop when the temperature gets too hot as a warning something needs checked. Check your vent and be sure it is absolutely clear, and the flapper on the outside is not stuck with lint buildup.
Nov 27, 2009 | Kenmore 62602 Electric Dryer
My iphone wont load up i did a reset on the phone to factory settings and now when it cuts on its stuck on the apple logo
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Sep 23, 2009 | Apple iPhone 3G
Itouch stuck on the playlist screen??
mine does this sometimes also, i'll be in a program and i hit the home button and the music/ close menu will pop up. i hit close or hold down home and it goes back. there was a new update to the unit so that might fix it also
Nov 30, 2008 | Apple iPod touch
Apple iPod touch Logo
485 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
