Question about Saws
My Skil 5250 Circular Saw does not turn on
My Skil 5250:05 circular saw has simply stopped operating. Push on, and nothing happens. Bad switch? Can I fix?
  • plotnick Oct 01, 2009
    Part arrived today - I installed it. Still no joy - so I guess I'm getting a new circular saw unless there is something else I can try.
  • Anonymous Mar 24, 2014
    The laser on my circular saw model number 134466 Master mechanic does not work how do I fix
  • 313 Answers
If you are pretty handy you can fix it your self. The part you will be looking for will look like this ( $8.00 PART) Look below for a place to buy it.
The diagram is here
Posted on Sep 09, 2009
Testimonial: "Thanks. I ordered the part. Let's hope that is it."
Why does the blade stop working on my circular saw when I'm using it
Your either pushing the saw crooked into the cut or the nut holding the blade it loose. Make sure you unplug it before you start fooling around with the blade.
Oct 13, 2014 | Skil 7 1/4" Circular Saw Corded 2.5 Hp...
I hava a 7 1/4 circular saw model # 5250. The blade broke off and we can't get the bolt loosened enough to replace the blade. Any ideas on how to get bolt off?
If you have no way to prevent the motor from turning when you try to remove the blade bolt, you are going to have to immobilize the armature to get it off. Remove the cap on the motor housing so you can remove or relieve the spring pressure on the brushes. Then remove the motor housing with the field, leaving the armature attached to the blade guard/transmission assembly. Now you can safely hold the armature while turning the blade bolt.
Oct 06, 2012 | Skil 5250 Circular Saws
Skil saw 5155 owners manuel
I found something on amazon, take a look here: Skil Circular Saw Model 5125 5150 5155K 5170 5190KC Owner Instruction... . I hope this was helpful. Cheers
Jun 05, 2012 | Skil Saws
How to open replacement switch for 5250 skilsaw
Sometimes the wires are push fit and are held in with a sprung wire. If they are on this one try using a very fine jewlers screwdriver or stiff piece of thin wire to release the wires in the switch.
May 26, 2012 | Skil 5250 Circular Saws
How do I install on/off switch on Skil Saw 3400
It just pushes in and out. It is held in by plastic legs on the top and bottom of the switch. Reach behind the switch and squeeze on the top and bottom legs to compress them while you push the switch out. The new one will just snap into place as you push it in. Here is a parts diagram if it helps.
Skil 3400 diagram
May 09, 2012 | Skil Saws
Motor runs, saw not cutting
Hi
If motor is running and the blade is not turnning the motor pinion gear is damage.
Go see this link for parts diagram.
http://www.ereplacementparts.com/skil-5500-f012550000-714-circular-saw-parts-c-130_160_843.html
Feb 07, 2011 | Skil 5500 01 7 1/4" 120V Circular Saw Kit...
How to replace saw blade on skil saw
On the side of the saw in the center of the blade, there should be a bolt to remove that will get the blade off. Some saws have a special wrench needed to remove it, but since you have a Skil, you should be able to use either a 1/2" or 9/16" wrench or socket to take it loose and switch the blade out for one of your choice. Hope that helps.
Oct 09, 2010 | Skil 538501 120Volt 714Inch Circular Saw
Promblems with the Skil Saw 5750, the bolt that holds the blade is to tight can't get it off
try using a ratchet instead of the provided wrench. Also, use a screwdriver to help hold the blade from turning
Mar 25, 2010 | Skil Factory - Reconditioned 7 1/4" saw...
SKIL 574 7.25 CIRC SAW LUBE / OILING
The bearing are lubricated for the life of the bearings. No lub is necessary.
Sep 03, 2009 | Bosch 7 - 1/4" Skilsaw Circular Saw
Saws Logo
537 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
