Question about GE 30 in. Profile JGP932 Gas Cooktop
One igniter won't work right on my gas cooktop.
I have a GE gas cooktop model JGP933 I believe. It is about 5 years old. The front right igniter won't light the gas unless another burner is turned on.
    President:
  • 704 Answers
If you're not getting the ignitor sparking (you should hear it) when you turn the burner knob on for that burner, it could be that either the ignitor is dirty or caked with some gunk and needs to be cleaned.
The other issue could be that the ignitor is faulty and needs to be replaced. If you want to confirm a faulty ignitor before ordering a new one, you can swap it out with one of the other ignitors on the cook top. Be sure to unplug the cook top from the outlet thou, to prevent getting a shock, as those little sparkers can give you a pretty good jolt!
Just remove the grates and burners to get at the ignitor for cleaning it. To get at the ignitor, youll need to go under the cabinet or counter that the cooktop is installed on in order to remove the ignitor and swap it with one of the other ones. You'll see that these are held in place with a retaining clip you can remove with a flat bladed screwdriver, etc.
If you find that the one that isn't working is faulty, you can order one from your local appliance service store, or get one online. www.searspartsdirect.com lists parts for almost every appliance there is, just enter in the full model number to get a parts list, etc.
Hope you find this Very Helpful and best regards!
Posted on Sep 09, 2009
Testimonial: "I was able to confirm that the igniter was not dirty. It looks like I'll have to pull the oven out to access the underside of the cooktop to complete."
Remove & replace main top
You should be able to if you have a few tools. First take a few photos as you go so you always know how to put it back together again. Once completed spray around the gas lines with soapy water to check for leaks. Good luck
Ray
Apr 02, 2014 | GE 30 in. Profile JGP933 Gas Cooktop
The valves on my GE Profile Gas cooktop are broken and need to be replaced. The gas does not come on when you turn them.
You may have to hold them down whilst turned on to intitise s flame then release the knob the flame should stay on as the fsd has proved to the gas tap there is a flame so will stay on
Jul 12, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
Cooktop model JPG933BEC2BB right front igniter quit working
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
May 12, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
After spraying stainless steel cleaner on the cooktop, with the knobs removed, the igniter won't stop ticking as if it's trying to ignite. All the knobs are securely in the off position. Could this be...
Yes, the moisture is probably the problem...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Jan 21, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
Striker on gas profile cooktop will not stop striking. will only stop if electic is turned off.
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 29, 2010 | GE 30 in. Profile JGP933 Gas Cooktop
Ignition stoped working on my ge profile gas cooltop
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jun 17, 2010 | GE 30 in. Profile JGP933 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Same one - ignition click will not stop. Is there a solution?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
wwttw
Sep 25, 2009 | GE 30 in. Profile JGP933 Gas Cooktop
GE Profile Cooktop JGP933
you hit the nail on the head remove the knobs and spray wd40 on each area where the valves been removed make sure no flame is present.
Nov 19, 2007 | GE 36 in. Profile JGP962 Gas Cooktop
GE 30 in. Profile JGP932 Gas Cooktop Logo
639 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
