Question about Vector VEC053D 1200-Watt Power Inverter
Fan does not work.
As I hook up the negative power cord to the invertor I hear a noise from the invertor. The invertor fan does not run but the invertor still operates. What I need to do to get the fan back working?
  • 615 Answers
Two things...one the fan only workk when the unit get hot or you created short the inversters are very sinsative and if you make mistake you are dead...see try it for ferw min and see...but first try to reset the unit and that by disconnecting the negative and positive from the back and turn the unit on to get all charges in the unit out then reconnect the cables do not forget to ground the unit to avoid sparks.
Posted on Sep 09, 2009
I have a 2007 Yamaha wolverine 350 the oil cooling fan will not come on there was no ATV to pick from
Okay, here is a quick test for you to try.
Unplug the fan and hook a testlight to the plug in and see if you have power going to the fan.
If you do have power, then the fuse/relay for the fan is good.
If you dont have power, then the fuse/relay for the fan is bad. Replace fuse or relay.
To test the fan, unplug it and hook a wire from the negative battery post and a wire from the positive battery post and touch negative to negative and positive to positive for the fan.
The fan should come on instantly. If not then the fan is bad.
If it does come on, then your fan is good and you must not be getting power to the fan.
check the fuse or relay and replace.
Other than that it could only be a broken wire.
Nov 29, 2010 | Yamaha RD 350 Motorcycles
One of my fans has started making noise, how much time do i have to replace it? Am I right in thinking that it making noise that it needs to be replaced?
fan noises are usually caused by worn out fans. but can be also caused by IDE/power cables hitting the fan blades. you will have to open up the computer to see where the noise comes from.
if it is a faulty fan, replace it sooner than later as it will get louder and louder. then stop making noise all together when the fan fails.
Dec 09, 2009 | Dell OptiPlex GX270 PC Desktop
Grinding noise in tower
Grinding noise in tower If everything on your computer is working fine then it is probaly a fan put your ear in the back of your tower near the power cord and see if you can hear the grinding noise better if you can then your power supply's fan is going out if not its probally one of the inside fans in your tower open up your tower and see if you can find which fan it is if you dont want to do this you should probaly get a tech to look at it it's a pretty cheap fix and it can save your computer from heat dammage
Nov 07, 2009 | Computers & Internet
Loud fan noise
You may need to reset the SMC. Unplug all cables from your iMac including the keyboard, mouse, power cable, DSL, everything. Wait at least 5 minutes. Now plug the power cord in making sure not to be pressing the power button at the same time. Connect all cables and press the power button and start your iMac. If you still hear the noise then take it in for service.
Sep 27, 2009 | Intel iMac 24" Core Duo, 2.16GHz Mac...
Fan has a internal rubbing noise when in motion. Is there a way to use some electrical/ teflon oil to ease it's pain.
MOTION NOISE OCCUR IN THREE WAYS
1. The bearing of the fan is not good, apply greese or lubricant oil on bearing as on manual
2. The fan blade is not fixed properly, tight all screws, some times its blade is bent correct it.
3. The fan is operating on square wave frequency when it is working on an invertor, use a sine wave frequency
Aug 21, 2009 | Dryers
Fridge dont run
if all fan working check compressor call service
Mar 31, 2009 | Frigidaire FRS26R4A Side by Side...
I have a ge above range spacemaker xl1800 it seems to work fine except their is a rattling noise when its running it sounds like a bad fan or something comeing loose it seems like its comeing from under...
The noise you are hearing is due to the fan. The fan is used to cool the magnetron during cooking, and because this fan is not working the magnetron is overheating and the thermal protector is opening, killing power to the unit. All you need to fix this is a new fan blade. The fan blade(look for part #80) is slipping on the motor shaft ( the noise you are hearing).
GE XL 1800
If the blade is broken then you can buy a new one from---
GE FAN BLADE
Please ask for further clarifications.
A Fixya rating would be appreciated if you find it useful.
Thanks
Rylee
Feb 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Louder whirring noise when turning on computer
trumpjd,
Usually on startup the fans work a little harder then slow down. On newer computers they still have noticable fan noise. Most of what ou hear while the machine is running after start up is the power supply fan. When it starts to go bad you'll hear it all the time.
randy320sgi
Jan 09, 2009 | E-Machines eMachines Desktop PC
T40 2373 ibm fan error
One of three things; 1- when the fan codes on some IBM's, the code locks in the bios, there is a download the has to be ran in order to clear the code and the machine to run properly. Check IBM's support site to see if this is the case for your machine 2- If the machine overheated in the process of the fan going out, then the processor may have been damaged, causing the problem and 3- if there was a malfunction with the motherboard which initially caused the fan to stop working, a new fan won't work either. Test the old fan by hooking power up to it, it is power direct and has two leads positive and negative, when power is applied it will run or not. If it does run then the problem is with the motherboard. Try these and get back to me.
Jul 29, 2008 | IBM ThinkPad T40 2373 Notebook
Vector VEC053D 1200-Watt Power Inverter Logo
139 people viewed this question
Top Vector Electronics - Others Experts
Craig Butler
Craig Butler
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
