Question about Pentax IQZoom EZY-R 35mm Point and Shoot Camera
Pentax zoom90-wr film camera has a message of H3
My pentax zoom 90-wr film camera gives me a message of H3 when I try to take a picture....I can't find manual. What do I do?
Thankyou Kim
dougnkim@oregonwireless.net
  • 1 more comment
  • kime Dec 09, 2007
    can you take my email address off my post, I wasn't paying attention...thankyou
  • alleybio Aug 02, 2008
    H3 message is given.
  • uncle ian1 May 11, 2010
    has anyone found what the H3 message means an how to fix it.?
informatica
  • 1114 Answers
SOURCE: Need a 'User' or 'Operating Manual'.
Go to the following page and select category "cameras", sub category "Digital SLR" & you will find all the *istDS manuals for download: http://www.pentaximaging.com/customer_care/manuals_literature Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 14, 2007
  • 125 Answers
SOURCE: How can I rewind film
I used to use point and shoot film cameras. My guess is that there is a button underneath which when you depress will automatically rewind the film. Sometimes the button is very small that you may need a ballpen point to press it. Hope this helps cuz i have no idea what the Pentax Zoom looks like. I am guess it is a point an shoot type and not an SLR. If it is a point and shoot type, you must be sure the battery has power or else it won't rewind.
Posted on Jul 18, 2008
SOURCE: Using Pentax lenses from 35 mm on the digital camera.....
I have old Lenses that I use; you must set your lens to manual, Switch left hand front of body. That should resolve the problem.
Posted on Sep 03, 2008
E-man_1
  • 56 Answers
SOURCE: Pentax K10D won't work with lens from Pentax K100 (film0
The lenses are probably manual focus lenses,
  1. Make sure that the apature ring is set to 'A' or automatic,
  2. if these are manual focus lenses then switch the focus switch on the left side of the camera body to MF
  3. If this still doesn't work, or you are having trouble with the apature ring then press the menu button to go to the  menu then press the right arrow key untill you are in the  Custom Settings, scroll through the custom settings with the up and down arrow keys until about the 2nd from bottom there is an option called "using aperture ring" set this to 2 (Permitted) This will make the camera take a image when lens is on any f-stop manually.
Try this and everything should work fine. If all this hasn't worked then try seting the mode dial on the camera to M manual mode. Cheers
Posted on Sep 10, 2008
SOURCE: AV flashing in LCD of camera whn zoom attached
I found on some lenses you need to go into the menu , select settings and change av appurature setting to 2 instead of 1 .
Posted on Mar 04, 2009
For my pentax 160 Iq zoom, I can load the film into the camera but I still can not take any pictures. What can I do? Any help is appreciated. Thanks.
Does that camera have a battery to advance the film and operate the unit? U might just want to check that out and replace the battery. If nothing happens with new battery, then the camera is fubar.
Sep 16, 2016 | Pentax IQ Zoom 160 35mm Camera
My pentax zoom 90 wr gives error H3 what to do
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
May 11, 2010 | Pentax IQZoom EZY-R 35mm Point and Shoot...
Pentax Zoom 70-x won't take pictures, Error code E7
This is the technicians code telling the tech where to start the repair. It is time to replace this camera since the cost of repair is more than the camera is worth.
Sep 24, 2009 | Pentax IQZoom EZY-R 35mm Point and Shoot...
On the lcd it shows "E" "E 9" and I do not know what this means and the camera will not work. What needs to be done
This question has been answered repeatedly. Pentax error codes are mostly for camera repair technician diagnosis and most of the time mean the camera is broken and needs professional servicing. Some Pentax Error Codes:
E: "E" often indicates a film jam. This code can appear when the film is inserted incorrectly, when the batteries are changed in the middle of a roll of film, if you are using defective film, etc. If "E" appears in your camera's information display, try to rewind your film manually (see your user's guide for instructions on how to activate your mid-roll rewind function), and try a different roll. If this problem keeps occurring, you might need to send the camera to us for repair.
E3, E7, E37: These codes often signal a problem with your shutter mechanism.
E9, E93-E97: These codes may indicate a problem with your zoom lens.
H0-H9: These H codes can also identify a problem with your camera's shutter.
U1-U9: These U codes may also indicate a problem with your camera's zoom lens.
These codes are standard for both Digital and film cameras.
Please rate our helpfulness to keep the service viable++++Thanks for using FIXYA
Sep 22, 2009 | Pentax Zoom 105-R Film Camera
BATTERIES DEAD, FILM INSIDE, NOT MY CAMERA, HOW DO i REMOVE FILM
Not really, the battery is going to be needed to power the rewind motor.
To try and open the camera, remove the film and rewind it will all have to be done in complete darkness and under such conditions you're likely to break something.
$7.16 is all you need for that battery including shipping:-
http://www.ebatts.com/pentax_iq-zoom-60x_digital-camera_batteries_part_b-151.aspx?GCID=C10847x066-perm3&KEYWORD=Pentax%20IQ%20Zoom%2060X%20Battery
Jul 01, 2009 | Pentax IQZoom 140M 35mm Film Camera
Can Film Camera lenses and Flash be used for Digital Camera Body
If u used to have a Pentax camera, i would recommend you buying a Pentax DSLR, because Pentax film lenses still works on Pentax DSLR. I still use some of my prime lenses on my K10D.
Jun 05, 2009 | Pentax MZ-60 QD 35mm SLR Camera
Zoom 90-wr camera keeps coming up with a H3 error
Its a Flex Strip problem .... U will have to get it replaced from a repairman ...
Oct 18, 2008 | Cameras
Can't take pictures.
Guest,
pentax codes are in repair manuals, not instruction manuals. H3 indicates shutter failure. this means anything from the flex circuit on the zoom barrel ( inside ) to the shutter itself. camera needs repaired.
Aug 18, 2008 | Pentax IQZoom 200 35mm Point and Shoot...
Zoom lens not retracting
May be a bit of grit gas got in. Do not try to manually manipulate it- this will wreck the motor drive. A Vacuum clean suck way have some affect. Certainly contact Pentax Tech Support Team .
Jul 02, 2007 | Pentax IQZoom 140M 35mm Point and Shoot...
Pentax
i think it means the film hasn't loaded properly. I had this and opened up the back and the film hadn't wound so it wasn't exposed. Anyway i just wound the film around a bit and shut the back and it turned on like normal. hope this helps.
Jun 30, 2007 | Pentax IQ Zoom 60S 35mm Point and Shoot...
Pentax IQZoom EZY-R 35mm Point and Shoot Camera Logo
245 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
