Question about Gateway MX6920 Notebook
I have a Gateway MX6920 laptop that my HDD crashed. It had an 120 GB HDD and I am not installing a 320 GB HDD. Everytime I try to boot windows it comes up with the message that hardware is not found(Hard Drive). I tried to format my BIOS and it will not let me move my hard drive as the primary. Please help need laptop back...writing important paper...and old fashioned ink and paper is no fun.
  • 615 Answers
I did not understrand what you mean by I am not installing a 320 GB HDD do you have two HD or just one? if you have two most HD guse external pins that make them primary or secondary check them and see if they do need to reset them...good luck with your paper...meantime do as I do go to the library and do your research and typing on a flash card so you do not waist time...good luck.
Posted on Sep 09, 2009
HOE DO I REMOVE XP OPERATING SYSTOM FROM HARD DRIVE
Are you trying to upgrade from xp to windows 7? First check if your hardware can support windows 7. You should have atleast 2 GB or above memory, 60 GB of HDD for windows alone so 320 GB HDD would be recommended. Your cpu should be dual core or core 2 duo atleast. If those are checked, upgrade to windows should delete your windows xp.
Or the other option is format the partition of the HDD where windows xp is installed.
Let me know more. So that we on the FixYa can help.
Good luck
May 28, 2014 | Dell Inspiron Computers & Internet
Won't boot linux cd
Try changing the boot order to HDD.
Mar 07, 2013 | Gateway Computers & Internet
Medion bios crash
It is not a BIOS problem, problem with HDD boot sector - try to reinstall OS correctly, or it is HDD hardware problems - replase HDD
Nov 15, 2012 | Computers & Internet
Hi i purchased lenovo nottebook G560 with config. 4gb ram, 320 gb HDD, intel i-3 processor and windows 7 home 64 bit. i tried to install turbo C compiler on my laptop but it didnt. i also want to install...
Hi
1.There you have a 32bit version of the compiler try to use the 64bit version
2.Install Windows XP to another hard disk and select the appropriate operating system via a windows boot menu
Aug 06, 2010 | Computers & Internet
Gateway computer - cannot boot up--
At boot up press F2 and enter BIOS. Here check if your HDD is recognized. If yes Ten your Windows is corrupted and needs to be reinstalled. How to install and save your data follow the link below:
Crashed Windows : No Problem
If the HDD is not being recognized then run Auto Detect to recognize the HDD. If it works fine, if not then the HDD may need a change.
Jan 25, 2010 | Computers & Internet
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
Non Disk error... Compaq HP NC6400 3 Gb ram 120 Gb S ata hdd toshiba 1.83 Ghz Intel Core _____________________ well everything happened as the lamp above our table in the living room fell on my laptop...
Check the boot sequence in BIOS and make sure that you no usb device connected to your computer and also try to change you Sata mode in BIOS and see if that works.
Jul 27, 2009 | HP Computers & Internet
My harddisk is gone. No recovery partition. Need to install XP.
Change the sata mode to IDE in the bios screen, it will be able to use the built in driver from the OS cd then
Jan 19, 2009 | Gateway MX6920 Notebook
Can't reboot dell 4100 dimension desktop
First put the hdd installation cd into the cd drive and try to boot. This should install the hdd driver as well as start formatting the new hdd. After the drive is formatted take out the hdd cd & insert the Windows installation cd into the drive. Boot. Windows should start installing on your new drive. After Windows is installed check the Dell support site for updated drivers for your system. Install drivers as needed. Any other software you had on your old drive will need to be reinstalled to the new drive. Hope this helps & please rate my answer. Thanks.
Dec 27, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Gateway MX6920 Notebook Logo
305 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
