Question about NetGear WGR614 Wireless Router
I just need to unlock the security on my wireless netgear router
  • 1,272 Answers
Follow the steps below to disable security settings on the router:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as None/Disable.
6. Apply the settings.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 09, 2009
    Master:
  • 441 Answers
Two things, you can reset the router and turn off the wierless security but you will need to reconfigure the rotuer to have internet.Second you can access the rotuer's setup page and get the wireless key there. You can ask you router manufacturer on how to access the router's setup page.
  • 585 Answers
Hi my name is Eric,
I hope I can help you with your issue ,
Press the reset button on the back of your router to reset it to default
generally this works, I do not have your model # but these have a reset for this reason. the read your ,manual for the default password admin admin I think
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
3 Suggested Answers
  • 556 Answers
SOURCE: Connecting a netgear wireless router to a 2wire
Are the router addresses assigned on the same subnet?
many routers have a base address of 192.168.0.1 and a subnet mask of 255.255.255.0 meaning all addresses 192.168.0.? are part of their network.
One problem can be that both routers can be using the same subnet -- not an issue if they are connected to different connection points (such as two different houses) on the internet. However when connected to each other in your house they are confused because they have the same two different networks with the same addresses. -- for slightly different reasons --
For those that want you to connect from one router to the wan of the other you need to assure the base addresses are in different subnets -- assuming the one connected to the internet is addressed as 192.169.0.1 with a subnet mask of 255.255.255.0 his network as stated before is all addresses 192.168.0.?. Change the second router to a base address of say 192.168.2.1 with a subnet mask of 255.255.255.0 his network is everything staring 192.168.2.? they are now different and it should work. On the wan side of the router you can assign a unique 192.168.0.? address not in the DHCP range of the first router or accept a dynamic IP address from the first router. The dynamic address is probably the easier and less problematic of the solutions.
For those wanting you to connect to a lan port and ignore the wan port they should also have asked you to turn off DHCP in the second router (where you do not use the wan port) and allow the first to do all the dynamic network address assignments. In this case you could have two DHCP servers on the network competing to assign possibly the same network addresses -- if they have overlapping ranges duplicate addresses could be assigned resulting in device connection issues for those with duplicate addresses. Even in this case you may need to assure the gateway addresses are unique on the network ie of both routers are addressed as 192.168.0.1 the second where the WAN is not used could become 192.168.0.2 (where that address is not in the active DHCP server's assignment range) or 192.168.2.0 (note the DHCP server had better be off or else the empty wan port 192.168.2.0 could become the "gateway" address of attached PCs and since there is no connection there will be no access to the internet.
I hope this helps
It is quite likely either solution could work if all the proper changes were made.
Posted on Dec 15, 2007
redhaze89
  • 854 Answers
SOURCE: Can Not connect to NetGear MR814 v2 Router with Acer Extensa 4420
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Aug 13, 2009
My netgear router on security lock, how do I unlock it?
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 09, 2012 | Gateway Belkin 54g Wireless DSL/Cable...
The signal from my router to my Samsung blu ray is not strong enough
There are several things you need to consider with wireless connection:
Distance - How far is the Netgear router from the Samsung Blu ray? Try changing the wireless channel on the Netgear router that can help boost the signal. Wireless Security- Have you enabled wireless security on the router? Is it WEP or WPA? Make sure that you input the wireless security key on the Blu Ray player and that you have setup wireless settings correctly.Number of wireless devices - Check the number of wireless devices(laptops, desktops, pda's, etc) connecting to the router as it also weakens the signal. And if wireless security is not enabled on your Netgear router, there's a chance that your neighbor might be connecting to your router via wireless.
You can also test how strong the signal is by placing a wireless laptop on the same location where the blu ray player is. If the laptop gets a weak signal as well, you can try placing the router closer to the blu ray player.
Oct 24, 2011 | NetGear WNR2000 Wireless Router
I need the security key to my existing wireless netgear router.
The Security Key is normally used for Wireless routers to protect your connection from any unauthorized use. As you have said that you do not have the Security key for your router with you, the best way to connect your ACER laptop to the Netgear router is by asking your Wireless service provider to reset the security key & freshly reentering the same on both of your HP & ACER laptops.
Feb 06, 2010 | NetGear RP614 Router
Can't get access to my secure netgear router
If your computer does not connect to the wireless router, most likely the wireless card has not been configured with the router's wireless settings ie. SSID, encryption etc.
To secure your wireless network, configure the wireless router and the wireless card in the computer, please click on this link and follow my instructions :-
Jan 29, 2010 | NetGear WGR614 Wireless Router
Hi i have a netgear DG834G router. My daughter has a pc in her room, and we have a wireless dongle. But i cant seem to unlock the router. Any ideas??
Check what is the wireless security set on the router by going to 192.168.0.1 on your browser. Check it under wireless settings.
Jan 28, 2010 | NetGear DG834G Router
I HAVE A NETGEAR WIRELESS ROUTER AND I NEED TO SECURE THE NETWORK SO OTHERS CAN'T ACCESS THROUGH MY COMPUTER
If you configure the Netgear wireless router with encryption and you configure your wireless card in your computer with the router's encryption settings, then other computers cannot access your router wirelessly unless they know the encryption setting. Please click on this link and follow my instructions to secure your wireless router :-
Jan 06, 2010 | NetGear WGR614 Wireless Router
I am trying to set the security for my Netgear router
You just need to change the Wireless Security Settings.
Just about every router is different so it's always best to use the guide provided by Netgear direct.
Make sure you download the correct manual for your revision.
NETGEAR GUIDES and SOFTWARE
--RescueTechLA
Nov 28, 2009 | NetGear WGR614 Wireless Router
I just got a netgear G wireless router and i cant figure out how to secure it i have internet access
Following site has steps of securing Netgear G Wireless router:
http://webupon.com/security/securing-a-netgear-wireless-router/
http://www.trueblade.com/knowledge/using-wpa-psk
Use the one which is more appropriate to you.
Hope that answers the question.
Nov 04, 2009 | NetGear WGR614 Wireless Router
Conect extra pc to netgear router
If you secured your router you should have created an encrypted password. You will need to enter this password on the computer for the wireless profile aquired from your router.
Mar 09, 2009 | NetGear WGR614 Wireless Router
I cant connect thru my netgear router model wgr614v7
If you hook your PC directly to the router using an Ethernet cable you don't need the key. You can log into the router and change the WEP Key to anything you want, but u have to be directly connected to the router not going through the wireless.
Jan 25, 2009 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
143 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
