Question about Dishwashers
My safe is lock with book inside
I have abrick security safe with the key, but the safe door shut and the book is inside and the key will not open with out the combination
    Sergeant:
    Champion:
  • 323 Answers
I guess you need the combination
Posted on Sep 12, 2009
I have a sentry safe csw3607 and I locked my book and keys inside. I can't find a factory code for my model anywhere online. Is there a factory code for this model?
if factory codes and how to open the safe were online their would be no reason for them then either notify sentery or a locksmith
Nov 07, 2017 | Sentry Home Security
I have a 2001 dodge durango, had to replace ignition cylinder last year, ran fine but now security light stays on and the car starts and shuts off the key cylinder was from O'Reilly and it wasn't for anti...
Shut the hood, make sure the back hatch is shut tight. Lock all the doors. Walk around and make sure they locked. Open the drivers door with the key. This should clear the security. If not lock it again and try the passenger side door. Reach in and unlock the drivers door. If it cleared then. Replace the drivers door latch on the back side. Inside the door.
Jan 24, 2015 | 2001 Dodge Durango
Change code number to a new number on safe e.d.safe s25ebf
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter "B" on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
Aug 04, 2011 | Office Equipment & Supplies
I cannot open sentry safe tc8 331. How can I change the batteries and where are they
This safe came with two long keys (maybe 6 inches). Rotate the key pad and it will come off. Insert one of the keys in the slot and turn. Should be able to pull the locking arm down now and open the safe. The batteries are inside, behind the plastic plate on the door. It slides up a little and then comes off.
Jun 27, 2011 | Sentry Safe TC8331: Safe Fire-Safe ®...
How do i change my code on my safe? it is a S-25E i have keys but want 2 change the code
Try this,
NOTE: The safe needs to be upright and right side up or the locking mechanism
won't work.
ELECTRONIC SAFES
Good luck
Thanks
Apr 29, 2011 | Office Equipment & Supplies
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Nov 01, 2009 | Home Security
I forgot the safewell electronic code and didnt have the key
won’t work.
ELECTRONIC SAFES
electronic keypad –159B. (These numbers are preset. You should change the code as soon
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell sales@safewellsafe.com
Good luck
Sep 14, 2009 | Locks & Locksmithing
I have a gordon digital electronic safe # P45891, lost combination .how to open it?
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Jun 30, 2009 | Safe International Digital Electronic Safe...
The security on my 1993 Grand Cherokee will not turn off
I may be able to help if you havent fixed it yet. I believe I had the same/similiar issue...
I would make sure all of the doors were locked with auto lock button on inside of door, then I would shut the door so all doors were locked from pressing the inside auto lock button. then I would use my key to unlock the trunk, open the trunk and close it leaving it unlocked. then i would use the key to unlock the drivers door and the security would reset... if not then unhook the battery for a few minutes then hook back up and see if that works.. glgl
Mar 10, 2009 | 1993 Jeep Grand Cherokee
How to open my safe with the code
How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Apr 18, 2008 | Sentry Fireproof Safe
Dishwashers Logo
Top Dishwashers Experts
