Question about Sony VAIO VGN-FE770G Notebook
I have a crooked key on my laptop keyboard that I would like to fix. They key works fine, but it is a little crooked
  • 615 Answers
All the keys are placed one by one via a spring and thee peaces of plastics and they are very small to be worked on if you can look under very carfuly you may be able to have one chance to do it correctly or you will brake it... I had to chamge my board three times and finally I am using external one for my laptop (I had extended warantee from bestbuy)
Posted on Sep 09, 2009
Both my space bar and M key are off. I dont know how to fix it.
There are multiple different designs for laptop keys - so the exact procedure may vary from one machine to another. A good source for instructional videos is:http://www.laptopkey.com/installation_guides.php#modnum
In your case, I would order and replace the existing keyboard, and keep the old keyboard for parts should a key come off in the future.
If you've never replaced a laptop keyboard before, the procedure isn't difficult, but you need to exercise extreme care when disconnecting/connecting the ribbon cable to the motherboard. If you break this connector, you'll end up having to replace the motherboard.
You can find replacement keyboards, and instructions, easily by typing in "Inspiron 1420 keyboard replacement" in Google.
Jan 01, 2013 | Dell Inspiron 1420 Laptop
Hp wireless keyboard not working
exact key board driver install then try
what keyboard model?
download load driver for keyboard
update keyboard driver
May 16, 2012 | HP Computers & Internet
My daughters key board on her lap top has started to act crazy you can't backspace and you can not type double letters you have to wait a second for it to keep typing any suggestions
First, try to connect an external USB keyboard & see if it will work fine.
If the external USB keyboard works fine, then you will need to replace your laptop's keyboard, as there is almost nothing that can be done to fix a defective laptop keyboard.
Jul 10, 2011 | Dell 0Y3740 Keyboard
Accidentaly spalshed some water on my laptop keyboard.
You may have to replace your keyboard at best. As this can be a difficult process depending on the laptop, I recommend a trained professional.
The loud beeping noise is called a beep code. One beep in most causes is a DRAM failure, which could mean that the problem goes deeper than a few messed up keys.
However once electronics become water damaged they are beyond repair. The minute amount of minerals in the water is enough to short out the tiny circuits in the keyboard and cause malfunction.
Jan 22, 2010 | Sony VAIO VGN-N325E Notebook
Question about liquid damaged dell inspiron 1545 keyboard
Just buy a new keyboard, should take care of the problem. You can buy a new key board on ebay for $10-13$. If you have any questions regarding keyboard installation, let me know. I can help.
Oct 01, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Switched keys
Hello there:
you have got dirt or dust under the key. get some canned air and turn off the laptop and blow out the keys really good. than restart the laptop and you should be fine
Jul 22, 2009 | HP 386209-001 Keyboard
Certain letters are not working
When keys go faulty the entire keypad needs replacing. You can't replace individual keys. I would suggest contacting dell and ordering a new keyboard, it's an easy fix: http://www.essortment.com/articles/install-replacement-keyboard-dell-inspiron_102151.htm
If you need to purchase one, I did locate: http://yallstore.com/laptop-keyboard-replacement-for-dell-inspiron-1525-p-4228.html For $16
May 23, 2009 | Computers & Internet
Spilled coke on the touchpad and keyboard of Acer Aspire 5920
Not so sure on the touch pad, but the keyboard is easy to remove. Make sure the laptop is switched off first.
There are a series of little clips holding the keyboard on. Look along the top above the F keys you will see 3 or 4 little clips, push each of them in and up (away from the keyboard) using something thin and blunt so as not to cause any damage.
There will also be some little clips each side of the keyboard, these do not push in, you need to manoeuvre the keyboard past these.
Lift the keyboard from the top as it slots into some grooves at the bottom. There will be a ribbon cable connecting it to your laptop, this is easily undone and the keyboard is off.
Jan 25, 2009 | Acer Aspire 5920-6727 Notebook
P200-RT3 Toshiba Note Book - Windows Vista
Yes, there is a way to shut down without touchpad. Look to see if you have a key on bottom left corner of keypad that looks like a little MS Windows icon (kinda like a 4-piece "crooked flag"). If you do, you are in luck. Press that key ONCE and let go and the start menu will "expand" and show you programs, settings and SHUT DOWN. Now just hit the UP arrow key (on bottom right side of keyboard) and the menu moves up one notch, to SHUT DOWN. No press ENTER and the shut down menu appears Move the arrow key again, until it says "SHUT DOWN and press ENTER again. That is it.
If you have no windows key (many laptops don't) then try pressing ALT and F keys. Sometimes this works. If it does raise the menu, then 5the instructions are the same thereafter (arrows and enter).
Another way to shut down is press CTR ALT and DEL (DELETE) together, all three keys simultaneously (but only ONE time). Then wait a second. This brings up a process window that has tabs for shut down (arrows and enter will work there too).
Now, when you restart, look for an icon in bottom right hand corner for "synaptics touch pad". or some other brand touch pad. There you can change your touchpad settings back to "tapping" for mouse clicking. You can also allow "click and drag" but I think that is dangerous, since you can accidentally "bury" files and folders.
Hit the solved/Fix Ya key on the way out. :)
Nov 11, 2007 | Compaq Presario Notebook
Sony VAIO VGN-FE770G Notebook Logo
856 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
