Question about Panasonic PT-AE700U-EC HD Cinema Front Projector Multimedia Projector
Permanent blue hue down one side of screen PT ae700 panasonic replaced lamp made no differance tried compressed air no change please help
  • 2,236 Answers
If the discoloration has a sharp pixelated edge, it may be the lcd panel. if the edge blends, it's the light filter (polarizer) that is burnt from excessive heat and dust. either one needs replacing.
Posted on Sep 09, 2009
Where can i get an optical block for a panasonic PT-AE700E and roughly how much am i looking at
USD150 for the Optical block for AE700
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Sep 04, 2013 | Panasonic PT-AE700E Projector Lamp
Panasonic PT-AE700E projector light does not turn on, instead the fan runs on high for an infinite time until turned off
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
have a nice day!
May 04, 2013 | Panasonic PT-AE700E Projector Lamp
How to reset panasonic projector ae700
Turn on the projector
MENU-
OPTION-
LAMP RUNTIME-
Press and hold the ENTER button for 3 seconds.
Turn off the power.
have a nice day!
Aug 01, 2012 | Panasonic PT-AE700E Projector Lamp
A section of the screen is a different colour to the rest. A brighter blue colour. Is this an indication that the lamp needs replacing?
hi,
it will not be because its lamp problem. if lamp have any problem it will affect the whole screen. may be its lcd or controlling circuit have some problem.
ok
Dec 20, 2010 | Panasonic ET-LAE700 Projector Lamp for...
Is this blue tinge on the left side of the screen a lamp problem or the projector itself. the lamp for this Panasonic PT-AE700E was replaced only about a dozen hours ago. what is an optical block, and does...
Your problem is the optical block failing. This is very common with the AE700s. It actually happened to me once before and I had it fixed. After having it replaced, it was recommended I run my fan on high mode, run the lamp on low mode and change the back lit color to black from blue to help thwart the issue. The optical block fails due to heat stress from the projector. Doing the things above lower the heat and extend the life of the block. I have a perfeclty good optical block if you would be interested as buying them new are extrememly expensive.
May 10, 2010 | Panasonic PT-AE700E Projector Lamp
Blue hue on right side screen
Try changing your vga/dvi cable,or it could be colour decay.
May 07, 2010 | Panasonic PT-AE700U Multimedia Projector
I have a Panasonic PT-AE500U projector i am on my 4th bulb now and i have a blue hue on the left side. It was on both sides, i had it sent in and cleaned and now theres only a hue on the left side. I have...
Optical block is the culprit! replacement is not too difficult. About the only special tool required is a long phillips screwdriver to reach the screws securing the block to the front panel of the set. Then, there are three connectors on the C board which is part of the block, one connector on the left side of the C board, one fan connector on the left side and then two connectors on the lamp driver board which is on the back of the optical block. Two recessed screws hold the block to the front panel and sometimes there is a third recessed screw to the left of where the lamp is located. Then the block slides out. Reverse the procedure to install the block.
Thanks for using FIXYA
Nov 27, 2009 | Panasonic PT-AE500U Multimedia Projector
How far to mount projector from screen, screen is a lp morgan rondo
It depends on a lot of factors -- how bright the area is going to be, the size of your screen, etc -- but you'll be roughly 9 to 14 feet from the screen for most settings.
I'm basing this on numbers for a PT-AE700U projector, as I wasn't able to find the AE700E.
Take a look at the ProjectorCentral.com projection calculator if you want to get precise about the distance for your environment.
But be sure to rate my fix as "Helpful" before you click that link! :)
Aug 17, 2009 | Panasonic PT-AE700E Projector Lamp
Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Nov 04, 2008 | Panasonic PT-AE700U Multimedia Projector
528 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
