Question about LG Refrigerators
Ice is jamming on external dispenser. open the door and ice falls all over floor. what could it be?
My freezer is leaking water all over the floor it can come ok for a few days then starts again also build up of ice inside freezer any ideas how to solve this??
Posted on Sep 09, 2009
Why does ice maker keep making ice?
The level sensor is jammed or not fully retracted
Aug 20, 2015 | KitchenAid (KSRD22FKST) Side by Side...
The place where the ice is held when I go to crush the ice it falls out the bottom of the freezer do I need a new ice container
sounds like that may be we had so many problems with ours that I tore it out and threw it away .
Mar 03, 2015 | Refrigerators
I have a whirlpool refrig model # ED5VHEVB06. The door where the ice comes out has a flap that does not close completely and a small black plug dropped onto the floor. Now the ice gets jammed and do
sorry , but to properly fix the problem you need to disassemble the door frame from the inside panel, if you are capable you may do but better to have trained technician to do it
Mar 18, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Lg lmx25984 ice chute flap will not open automatically
On Mine, the solenoid connection fell off that allows the ice to dispense, Thank you so much!
Aug 04, 2012 | LG LMX25984ST 24.7 Cu.Ft. French 4-Door...
Our new 48" Viking side by side does not feed ice cubes adequately. If you need several glasses of cubes it stops feeding and when one opens the freezer door they are piled up and fall all over the floor....
I experienced the same problem several times with our VCSB483DSS also.
What I found was that the ice come down the chute side way and got stuck at the flap in the door. As you continue to press for ice, the machine pushes more ice & they all back up in side the chute and in the door, ready to dump on unsuspecting person who open the freezer door.
I think the the problems are:
1 - over application of foam insulation in the chute pathway in the door.
2 - possible bad timing on the flap opening causing the falling ice to get stuck.
My solution for the past 6 years:
1 - clean out the over application of foam insulation - this reduce the incident frequency from once a month to once or twice a year.
2 - inform my family member that if while you pressed for ice, and the ice is not dropping, but you hear the motor still cranking away, stop pressing for ice immediately. Stick you finger up the dispenser to make sure the flap is open, and push the ice to un-stuck them. And finally, be prepare to get 2 cups full of ice.
Viking may make professional quality fridge (13 years experience in restaurant business), but ice & water dispenser is not their strong point.
Oct 09, 2010 | Viking 42 in Built In Professional...
Freezer frosts up to the point of not being able to open the door without ice falling on the floor. Can this be fixed?
Yes it can be fixed, This can be as simple as replacing the door seals if bad to replacing the defrost board.If the seals are good and the doors close and seal as they should then the defrost is not working properly.
Aug 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
When dispensing ice from door,,some of the ice falls on the floor...opening seems too large for a glass...any solutions???
It sounds like the ice guide ( pt # 2180224 ) is missing from the arm you press to get ice . This clear piece just snaps on to the arm . This piece , narrows down , to about 2 " , so that all ice goes into container .
Sep 29, 2009 | Whirlpool GD2SHGX Refrigerator
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
79 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
