Question about Motorola Mobility RAZR V3
Front LCD screen on Motorla Raza v3m
The small Lcd screen lights up and only shows alltel logo... does not display time etc.
  • jajd49 Dec 24, 2007
    Thanks but it didn't work....great web site and service that you offer.
    Brigadier General:
  • 7,752 Answers
Do a master reset.......or reflash the firmware.
Posted on Dec 21, 2007
Have no graphic display on my sony vaio laptop sony model PCG-6N1L.\r\ncan not find the service manual for the laptop. The laptop power light turns on, but no graphic display is showing. Need too find what...
Tell me if there is any chance u could see any light on ur LCD screen?
Or
If u could see any icons or logo, the light in ur LCD usually got faulty in the LCD monitors!
Dec 02, 2010 | Sony Computers & Internet
Blue lights are on laptop but screen is black
test and external monitor to confirm if system actuallty boots up. If it does, and display issue happens from the time you start the system and not able to see even the Dell logo showing on the screen, could be a problem with the LCD. try to remove and reconnect the LCD cable to the motherboard to see if it helps. If not, you may have to get an LCD replacement.
Aug 31, 2010 | Dell Inspiron 1525 Laptop
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
RAZR V3M thinks it's always open - Screen will not turn off
in the top right corner you are suppose to have a little circular magnet that changes the screen when the phone is open or closed. I just changed my housing yesterday and took the magnet out and put it in my new housing but for some reason i have the same problem as you. so maybe you lost the magnet when you replaced the lcd and if that is the case then you are screwed. try have Motorola fix it, don't tell them you replaced the lcd
Dec 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Outer Screen wont work
wow, what you need to do is have both the flexcable and LCD replaced....so you will have to go to a mobile service center and have that done.
Oct 26, 2007 | Motorola Mobility RAZR V3m Cellular Phone
17" Monitor keeps going black
Hi Rahni, It's a very common problem. LCD's use four small Cold Compact Fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 18, 2006 | HP Pavilion F1703 17" LCD Monitor
Screen goes blank
Hi jkm007, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 12, 2006 | Videoseven V7 L19PS 19" LCD Monitor
Motorola Mobility RAZR V3 Logo
65 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
