Question about Sony Computers & Internet
Sony vaio media test failure , check cable exiting pxe rom
  • Sony Master
  • 32,281 Answers
This fault is usually a disk controller problem/fault or the hard drive is not making proper connection or most likely the hard drive is faulty.
Try reseating the hard drive first.
If this doesn't work, check the BIOS to see if it detects the hard drive.
If the BIOS cannot detect the hard drive then remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external hard drive and cannot open the folders and files, then the hard drive is confirmed faulty.
Install a new hard drive and install Windows on this drive together with the device drivers and programs to get a working laptop again.
Posted on Sep 09, 2009
Keeps saying boot failure along with Ethernet controller v1.06 and media failure, check cable
What you are describing is a hard drive issue, remove hardware and reseat it back in place sometimes this will restart the hard drive. If this fails have it tested.
Jun 04, 2012 | MSI Computers & Internet
Tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
Media test faiture, check cable error message ,
The error is related to your network interface card. In a lot of laptops this is integrated to the motherboard and can't be switched out at home. You will need to take the laptop in for service to have the card replaced.
Sep 27, 2009 | Sony VAIO Notebook
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
Powers up does not boot
Sounds like a bad harddrive! If possible try replacing the harddrive!
Ill bet that would solve the problems you are having!
Dec 27, 2008 | Sony VAIO PCG-K35 Notebook
Sony vaio pcg-fxa36 will not boot get error realtek RTL8139(A/B/C
ok, what is happening is the laptop is trying to boot from the ethernet port, what you have to do is go into the bios (this is usually F2 on boot) and change the boot order to hard drive, save settings and exit the bois screen, the pc should now boot to windows
kind regards and please don't forget to rate us
Dec 03, 2008 | Sony VAIO FXA36 Notebook
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
Problem with sony vaio laptop
Your Harddisk drive did not detect by your motherboard, try to remove the IDE cable and the power cable to the harddisk and return it back and surely fit in..
tnx
-micro
Feb 09, 2008 | Computers & Internet
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
Dec 15, 2007 | Toshiba Satellite A105-S4004 Notebook
Computers & Internet Logo
174 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
