Question about Dynex Voice-Certified PC Desktop Microphone
Computer does not recognize microphone
I got a new computer. Plugged in my Dynex Desktop Microphone from my old computer. Apparently, this computer is not recognizing it. I had the computer search for new hardware, but came up with nothing. Any help appreciated.
  • 313 Answers
Http://www.dynexproducts.com/t-drivers.aspx try this link it is for the support and web load the drivers and then connect the mic and follow install routine. hope this helps A..
Posted on Sep 09, 2009
ConnectLand cl-me 606 goose neckdesktop microphone to desktop
Look for a 3.5 mm microphone port on the computer. Usually the port on the back of the desktop will have a pink surround. (There will be other ports there; the usual minimum are the green port for speakers and blue one for line-in.) Put the 3.5 mm jack on the end of the cord on the microphone into the port. If you have an add-in sound card, use the microphone port on the sound card.
Some machines will also have a front panel microphone port. This will have a small mike icon next to the port.
Next you need to ensure that the audio device is set to Microphone. For Windows systems (Vista/7/8), enter the Control Panel and go to the Hardware and Sound panel. Click on Manage Audio Devices under Sound. Then click on the Recording tab. Check if the microphone listed as plugged in. Make this the default recording device. (XP has a slightly different name for the panel.) For XP through Windows 7, click on the start button and then find the Control Panel listed on the right. For Windows 8, from the desktop, press the Ctrl and X keys at the same time. Then find the Control Panel in the list. (Alternatively, activate the Charms menu, Ctrl+C or hover on the upper right of the screen. Move down and click on the gear (Settings). Then select the Control Panel.)
If the computer doesn't indicate that the microphone is plugged in, make sure that the 3.5 mm plug is in the correct port. Next try the microphone on another computer. The audio card port could be damaged or the microphone cable could be faulty. If the microphone works on another computer, you can try a USB audio adapter (StarTech ICUSBAUDIO or similar) or a new sound card. (Note: some older sound cards do not work properly on newer versions of Windows. If you have a sound card installed and the motherboard has an on-board audio device, remove the sound card. Enable the on-board audio in the computer's BIOS. Install the appropriate audio drivers. Try that audio device. Accessing the BIOS will depend on computer. Often you can press Esc, F1, F2, F10 or Delete repeatedly after you turn on the computer. If Windows starts to boot, turn off the system and try again.) If another computer doesn't recognize the microphone, I'd recommend a new microphone. Fixing the cable isn't worth the effort.
I hope this helps.
Sep 20, 2013 | Computers & Internet
How do I configure my Dynex USB microphone?
try uninstalling it and then re-installing it:
Plug the USB connector into an available external USB port on
your computer or laptop. On most computers, drivers install
automatically and your microphone will be ready to use.
Note: On Windows, if you are prompted with the Add New Hardware Wizard, follow the steps to download and install the driver.
Jul 07, 2012 | Dynex USB Microphone
Bought new dynex dx-740 earclip headset with microphone. earpiece works but computer not picking up microphone.
Have you installed the software for your headphone? Your computer might not pick up your device because it doesn't recognize the device.
Mar 06, 2011 | Dynex Earclip Headset with Noise-Canceling...
I plugged my Microphone in the pink slot and it doesn't work on Vent, nor does my computer picks up the microphone
Make sure the Front Pink In is enabled.
Find the Volume icon in your Taskbar (little speaker, Right Click - Open Volume Control) or in Control Panel / Sound and Audio Devices. Find Device Volume / Advanced and uncheck the Front Pink In Mute box and slide the volume UP.
Mar 24, 2010 | Dynex Voice-Certified PC Desktop...
Just stopped working..
check control panel for audio setting to make sure it is enabled and recognized
Feb 26, 2010 | Dynex Voice-Certified PC Desktop...
My microphone is plugged in but it wont let me record only hear what im saying through my computer speakers???
You have to have a audio recorder viia your computer software. Try NCH or Audicity both of which are freeware programs
Feb 04, 2010 | Dynex Voice-Certified PC Desktop...
Audio is very low
I called Dynex and was told toreplace the microphone.
Oct 10, 2009 | Dynex Voice-Certified PC Desktop...
Mic is recognized by the computer, but not registering sound. Help?
Try this:
click on start, control panel, hardware and sound.
Click on manage sound devices and click the recording tab.
Make sure you have a tick on the mic you want to use and double click on it.
Make sure it says" Enabled" in the device usage box, then click on levels.
There should be 2 sliders, one is the volume of the mic and the other is microphone boost make sure the Microphone volume is near or at 100
It not too good using microphone boost but you may need to use it a little, if you set it too high you will get the horrible feedback screech.
I hope that helps..
Mike
Jul 30, 2009 | Dynex Voice-Certified PC Desktop...
Acknowledging Microphone
Sounds like the mic is bad. The only way to confirm this is to plug a different mic into the computer and see if that works. If the second mic gives no sound then the computer may have an issue. Hope this helps.
Nov 04, 2006 | Logitech (980240-0403) Microphone
Dynex Voice-Certified PC Desktop Microphone Logo
1,143 people viewed this question
Top Dynex Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Dynex Audio Player and Recorder Expert? Answer questions, earn points and help others
