Question about Soleus MA-9000AH Air Conditioner
A/C has red light like a trash can in the middle.
I have a red trash can light in the middle. I have a 9000 A/C btu system.What does it mean?
    President:
  • 1,922 Answers
Empty your water bucket
Posted on Sep 27, 2009
Samsung 75 smart tv , is power on or off when red light is on ????
Red light means that the unit is in standby mode, It has power but is not turned on.
Jul 24, 2015 | Samsung New 75"" Class 74.54"" Diag. LED...
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
Hi, how to you add more freon to 9,000 btu fugitronic portable a/c? Thanks
From the condensing unit you can see two valves. Connect the blue hose to the bigger pipe sometimes marked "S" to the suction manifold gauge with the blue dial.The discharge valve "D" is the smaller pipe and connect it to the red hose going to the red dial gauge. After connecting the hoses respectively, open the blue handle of the manifold to release air from the blue hose and close it. The same thing should be done to the red handle valve of the manifold. Connect the yellow hose to your freon cylinder and slightly open the cylinder valve while connecting it to the middle of the gauge manifold. Now, there is no air from all hoses and you can start charging freon when the unit start running. Check suction pressure and the Rated Load Ampere of the unit
Sep 03, 2011 | Fujitronic FA-9000 9,000 BTU Manual...
I have the Commercial Cool Model# CPR07XC9-LW 7000 BTU and it has been shutting down in the middle of the night. It beeps and a red light flashes on it. What does this mean?
It means that condensed water has accumulated in the unit. In the rear, on the bottom right, there is a water outlet drain. Tilt the unit slightly to drain the water in there. Be sure to unplug the unit first.
Jul 13, 2011 | Haier Heating & Cooling
Need a owners manuel for haier air conditioner 9000 btu
To help you with the correct Owners Manual, I will need the correct Model Number for your Haier AC Unit. They make 3 different models for 9000 BTU.
Please advise. Thanks.
Jun 08, 2011 | Haier Heating & Cooling
My blackberry bold 9000 led stays red for a few seconds and then shows the charging icon then cycles back to the red light. It won't turn on.
It can be deduced from your problem that there is an error on the operating system of your bold 9000,I also use a bold 9000 and i experienced the some problem 2 wks ago,
This solution helped me out;
1.You have to do a hard reset on your bold,which means you have to remove the battery from your phone and re-insert it back after 10mins,
2.if the above solution doesn't work,it means you have to flash the entire ROM random operating memory of your phone,which requires the use of a particular software which can be got from any phone technician in your area.
Have a nice day.
Jun 27, 2010 | RIM BlackBerry Bold 9000 Smartphone
We have a 9000 btu portable frigidare air conditioner, we are constantly having to manually drain the bucket even with drain pump hose attatched. Is it possible tat the drain pump is broken? Occasionally...
Wow maybe you have a lot of moisture in the air.
It is a strong posibility the pump has trash in it. periodically clean out the pump for best results.
I realy have never even seen a 9000 btu portable ac or worked on one. Just guessing.
Jun 25, 2009 | Frigidaire FAP094P1Z Portable Air...
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Amana Portable Electronic Air Conditioner 9000 BTU
Unfortunately I am unable to find the Manual in our system. Here is the information that you can use to contact them directly. They should be able to send you a new one.
Consumer Affairs Address:
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729
Jun 27, 2008 | Amana AP073M 20" Portable Air Conditioner...
Soleus MA-9000AH Air Conditioner Logo
220 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
