Question about HP Pavilion dv4000 Notebook
Monitor keeps shutting off after a few seconds- hp dv4000notebook
I have the same hp dv4000. The monitor began to flicker ONLY when on battery power several months ago. Now the monitor backlight only comes on for a couple seconds, battery or AC power. It will come back on for a second or two if I hit the button that sticks up (the button that turns off the monitor automatically when you close the notebook). Sounds like the same problem as the original poster. Any suggestions would be appreciated.
  • HP Master
  • 32,281 Answers
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Posted on Sep 09, 2009
I have trouble booting up my Dell Latitude D600. When I press the power button status lights on right flicker for few seconds then shut off.
try removing the battery (keep ac power), test
if nothing, try the opposite,
remove both ac power and battery test,
for some reason holding down f10 and cursing at the machine seems to help. Mine does this but typically will boot after a few attempts (and lots of cursing)
Sep 12, 2011 | Dell Latitude D600 Notebook
Why does my hp pavilion dv4000 laptop shut down when it wants?
Check your settings in the power options menu located in the control panel make sure it is set to not turn off although I do not recommend doing this because it is set to keep the battery cool in battery mode just tweak the plug in mode. Set this to never when it is plugged in. If you set the other the battery one it will run forever and will eventually ruin your computer. Just a suggestion! John
Jan 22, 2011 | HP Pavilion dv4000 Notebook
Need to do a hard reset for hp pavilion dv4000 laptop
Hi, you can do a hard rest by following these steps:
Turn off the pc
Remove the cables and the battery on the laptop
Press & hold the power button for 5 seconds
Reinsert the battery and cables to it
Turn on the pc
that is how to do a hard reset....
May 15, 2010 | HP Pavilion dv4000 Notebook
Screen for hp pavilion dv4000 won't turn on
Try rebooting the start up disc the laptop came with,then go to hp's web site using a friends computer to get the disc you need.Or if its still under warranty return it to the stroe you got it from.By mail or some other means of transportation.
Feb 15, 2010 | HP Pavilion dv4000 Notebook
My Hp pavillion dv4 notebook pc's screen is flickering quite badly. It happens every few seconds and everything seems to jump up and down once and go back to normal. Tapping or hitting screen or any part...
Flickering is a back light issue, jumping around would be caused by the screens reaction to a bad inverter and so would the backlight as well. So flickering backlight and jumping would be a inverter issue causing both problems so I would replace them both.
Thanks if you like my adivice please rate it with the thumbs and leave feedback!
Dec 19, 2009 | HP Pavilion dv4000 Notebook
HPW 2007 goes to sleep
Try going to the control panel after clicking on the start button and it will have an icon that says "power options", there will be options there for the sleep functions for the monitor etc.
Nov 30, 2009 | HP Computers & Internet
My laptop monitor keep shutting down....
Check the display power settings in Control Panel.
Oct 04, 2009 | HP Pavilion dv4000 Notebook
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Screen goes black on my hp pavilion dv4000 notebook
Try connecting an external monitor to the laptop, power up the monitor first then boot up the laptop. The video data will switch to the monitor automatically, check if the monitor dislays a normal image and see if the image stays on the monitor.
Also press and hold the Fn key and press the F4 key, these keys toggle the video output between the LCD screen and the video port.
Test to see if this functions correctly.
Get back to me with the results of the tests.
Jun 03, 2009 | HP Pavilion dv4000 Notebook
Hp dv4000 won't power up
Try this solution :
1. Disconnect the AC Adapter.
2. Remove the Battery.
Note : Please see that there are no external devices or cables connected to the Notebook.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook.
Additionally, try removing and reinserting the RAM sticks by following the instructions listed in page number 119 of 266 :
http://h10032.www1.hp.com/ctg/Manual/c00530488.pdf
If the issue repeats, try connecting the Notebook to any Desktop Monitor and press the FN and F4 key so that the display will transfer to the desktop monitor connected.
If there is no display on the LCD of the Notebook or on the Desktop monitor connected, issue can either be with the Graphic Card of the Notebook or Motherboard itself.
I am sure these instructions are helpful.
Jul 19, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
542 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
