Dishwasher finishes cleaning cycle and then sounds like it is draining. However, seems that when the...
(More)
Dishwasher finishes cleaning cycle and then sounds like it is draining. However, seems that when the dishwasher has been drained the pump (?) continues trying to to drain the machine and it simply never stops (makes a sound like the pump is going but there is no water to pump - a bit like a waste disposal unit when no water is running) We have to turn the machine off at the mains to reset it but then next wash cycle it does the same. Seems to wash ok but it is the end of the cycle when it appears to get confused. New pump or is there a part that needs cleaning/ replacing to fix the problem? I'm just not sure where to start looking. Any help would be appreciated.
there is no water coming in through the dishwasher when i turn it on. it doesnt even sound like its...
(More)
there is no water coming in through the dishwasher when i turn it on. it doesnt even sound like its running and i checked all the connections and the power supply and everything seems to be fine except the water. i took everything apart and its completely clean it worked for about a week when i got it and now there is something wrong with the water pump or something idk
Kenmore built in dishwasher - electronic purchased 2002. A light is on, I press start and it does...
(More)
Kenmore built in dishwasher - electronic purchased 2002. A light is on, I press start and it does not work. I have pressed the handle area and sort of jiggled it and it worked for a limited time- a few seconds.
