Question about Freezers
Ice machine just hums
I just got an old ice machine (for free). I plugged it in and it turns on but nothing happens but it hums. If you push the ''clean cycle button'' you hear it click or try to cycle or something. We didn't have it hooked up to an actual water source, but just some tubing into a bucket. I just didn't know it would even turn on. What is the best way to test an ice machine and how can I tell if it works? I don't get the feeling that it's completely broken, but I don't quite know where to start.
Thanks,C
  • Mike Smith
    Mike Smith May 11, 2010
    This might be a little difficult question to answer . First , the model number is needed . Remove the front lower panel , and plug in . Are the front coils clean ? Do the front coils get hot eventually ? If they do , this means the compressor is working . You will need to remove the heat wire cover and the cutting grid asembly . Pour (spray) water into the white busket inside . Do you see the water being pumped over the aluminum plate , above the bucket ? If you do , then the pump(recirculating) is good . If not running over the plate , pump is bad . If water runs out the bottom , plug is missing . If you would care to reply back to this thread with the answers to these questions , either myself or another expert will gladly help you go deeper into a repair of this order .
    President:
  • 704 Answers
First off, you cannot use a bucket of water and a line to get the ice machine to operate. Ice makers don't have a suction pump in them, they rely on having a water supply line with pressure to push the water into the machine.
You can connect the machine to a water line and see if it will cycle, that is, take water into the unit without leaking.
Beyond that, in order to check out the unit, you will need to provide the Brand and model number in order to find a user's manual, which will provide all the details on operation and installation for it.
The good news is you might have a nice ice machine for free.
Hope you find this Very Helpful and best regards!
Posted on Sep 09, 2009
Will not turn back on 3 beeps
remove the screw(s) and slide the cover towards the front (the cover over the control board near the wash/ice switch.) with the machine on carefully locate the reset button on top of the circuit board and push to reset..
Mar 18, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km-900mah ice maker won't start the freeze process
cycle is, fill cycle for 1 minute first. If there is not water entering the unit when first turned on, look for that issue. Water turned off, water valve not working or some restriction, clogged water filters, etc. That is got to happen first. Don't over look the bin stat being bad. Nothing happens if teh bin stat is bad. It sends voltage to the control board that runs the unit.
Jul 28, 2012 | Hoshizaki Freezer Commercial Ice Machines...
How do I defrost the unit?
You give little to go on as to what you have. Self-defrosting? Freezer/refrigerator combo?
Assuming you have an old-style, non-defrosting freezer, the only way to do it properly is to empty it and turn it off until the ice melts. Open the door(s) and surround the base (floor) with towels to catch the water.
UNDER NO CIRCUMSTANCES USE ANYTHING HARD OR SHARP TO REMOVE THE ICE!!! The rule is to use nothing sharper than a Q-tip.
When the ice is soft, a plastic mallet may help in knocking the ice free, but gently... very gently.
If you cause a leak in the (probably aluminum) evaporator, have enough money budgeted to replace the machine. Repair costs would exceed the replacement cost in most cases.
When done defrosting, re-start the unit and let it run for 24 hours to ensure that the unit can attain temperature... not doing this puts your frozen product at risk.
Jun 18, 2011 | Freezers
Frost-free fridge-freezer; internal floor icing up
drain plug and or line probably plugged should be clear if ice was problem in between the casing shouldnt be a problem let unit run normal and check temp the amount of high humidity and usage [open and closing of doors] has caused a lot of frost free and regular units to frost and or ice up
Sep 29, 2009 | Freezers
Icemaker will not STOP making ice
check the sensor that tells the machine to stop harvesting.
Jun 30, 2009 | Freezers
My haier 5cu.ft. freezer stop freezing
Sounds like the unit has quit, or check the wall outlet to insure there is power there.
Nov 23, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Sep 06, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezers Logo
57 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
