Question about Northstar Generator 20 Hp, 13,000 Watt, Trifuel
Northstar generator w/GX620 engine shutting down
My generator model#10500SBG will not run anymore,although it ran fine for 2+ years. Natural gas version,I have 7" water column pressure at regulator. It will start ok,but then sputters to a stop. It has a keihin 22GA-SE12 carburetor.No one seems to know-help!
  • 615 Answers
I been using gen for over 20 years on my farm as backup for my solar system and one issue the haeds...many users forget or no one tells them that they need to adjust the heads after every 40-50- hours and any changes in the setting will not allow the grn to start ot it will run for a few seconds than die...look for the exact seerting of the in and out and check tghem and see if that help...good luck. remmber in winter you need low grade oil not high or use synthatic better.
Posted on Sep 09, 2009
Generator is two yrs old only had a couple of outages maybe totaling thirty hrs Generator ran great and also ran every wk for its exerciser cycle. The generator didn't start on this cycle and the system...
Is this a natural gas fueled generator? Sounds like a fuel problem, i would go through the fuel system and find out whats wrong. If its a natural gas/propane unit its most likely a bad regulator or low pressure.
May 04, 2017 | Eaton Electrical Supplies
Surging
It definately sounds like a fuel problem, lack of fuel..I assume it is running on LP or natural gas. The hose running from the demand regulator goes to the carburetor/mixer. When it gets to the carburetor, there is an adjustable main jet. It is different on different models, but is usually easy to find. There is probably a screw slot in the end of the screw head and a spring under the head. Start it up after locating the screw and open the jet just enough to even out the running. It was factory set, but barometric pressure and altitude and different fuels in different areas will decessitate different settings.
Please let me know if this fixes your problem, Robert
Jun 27, 2013 | Kohler 30RESA 30kW Standby Generator...
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
Generator with natural gas conversion intermittently sputters
running out of time and too rich
suggest that you call in an auto gas technician to check and adjust the regulator /converter for the gas to get it running right
Jul 03, 2017 | Grilling
Small 7kw Generac has always sounded rough over the three years we've had it. Oil and plug are fine but lately, after warmup, engine seems to misfire and eventually shuts off during the normal weekly test...
If the generator is out of warranty, you can try spraying a short shot of ether into the intake of the generator as it is running rough. If the engine smoothes out for a few seconds, and returns back to original state, then it is likely running lean. Check the gas regulator (this is LP or natural gas I am assuming since it is standby), the vent may be clogged on the bottom of it.
Feb 11, 2010 | Generac Guardian 100 Amp Transfer Switch...
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
Northstar Generator 20 Hp, 13,000 Watt, Trifuel Logo
538 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
