Question about Polaroid FLM-3734B 37 in. LCD HDTV
TV will not come on and there is a buzzing sound when it does
Sometimes it works but mostly it doesnt.
  • 11,896 Answers
You may have the extremely common power supply failure. They capacitors have been going out quick and also overheating causing tv not to stay on or power on at all. You can test it with voltmeter to see if it is putting out power.
Posted on Sep 09, 2009
Westinghouse tv power box making buzzing sound
Hi I'm Peter, There is a bad connection and most likely the buzzing sound is a relay going bad internally.
Apr 19, 2014 | Westinghouse Televison & Video
I have a proscan 42LA45H 42 in television that has started making a buzzing noise from the back. What is causing this, and what do I need to do to fix.
Hi
If picture and sound is Ok, and only this buzzing sound is heard from the back of the TV, It should be due to core soose of some ferrite cored transformers inside, especially to the power supply regulator board of the TV. Open the back cover of the TV and swtich it ON. Listeen very carefully which transfromer makes the buzzing noise. Just trouch and press the core of the transformer suspected with some non-cunductive material like glass rod, or a stick of dry wood. You can identify the transformer that makes noise by this way. After identifying the exact transformer; switch OFF the set, unplug it from mains socket, apply some "Super Glue" like fast boanding glue to the joint of core of that transformer. Allow sometime for the glue to set. This will solve the buzzing sound problem of your TV. OK
Jul 13, 2011 | Proscan 42LA45H 42 in. LCD TV
Im having a problem with some sort of power issue, sometimes it works and sometimes it just doesnt come on. i can hear a buzzing noise but it doesnt spin can you help thanks
Hi!
I think I had this kind of issue before on my computer. I sorted it out. First I check the motherboard and wiring inside if there are any wires touching the fans because of the buzzing sound. Found nothing. I noticed that the buzzing sound came from my hard drive. It seems that it's not getting enough power that's why its struggling to spin. What I did was I changed my power supply to higher wattage and everything was fine after that. You can give it a try though. If it still the same issue, you might as well try a different hard drive.
Regards!
Feb 14, 2011 | Computers & Internet
Buzzing sound + Tv picture is very weird.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS.. AND ALSO ALL FUSES AROUND IT .THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE.
GOOD LUCK
May 23, 2010 | Polaroid TLA-01911C TV
TV Doesnt work
replace the flyback transformer.
Mar 01, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Odd sound from Samsung DLP TV
Buzzing could be related to the lamp/ballast connection. Try removing and reinserting the lamp look for arching marks on the contacts that would suggest that the connection wasnt good.
Mar 29, 2008 | Televison & Video
Buzzing sound from my tv
tv makes a buzzing sound when i turn on the set, than stops.
Dec 10, 2007 | Harsper HP-4200VPM Television
My tv is buzzing and doesnt show a picture
sound like u have a bad flyback xformer also u need to replease horizontal output xsistor
Dec 08, 2007 | RCA F32648 32" TV
Buzzing from tv
If the TV is working normal otherwise then most likely you have a A.C. transformer or choke that is vibrating at 60hz or what they call the deflection yoke is buzzing. Niether issue is easy to get rid of. If the buzz is comming from the speakers, make sure you have the connections to the TV are correct.
Feb 28, 2007 | Philips Magnavox 20MS3442 20" TV
Polaroid FLM-3734B 37 in. LCD HDTV Logo
148 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
