Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Top part of Screen is Black
I have a 55in Hitachi rear projection tv, the top of the screen is black about 6 inches down. It use to go back and forth now it stays the same all the time.
SOURCE: watching rear projection tv.
we have a sony rear projection tv and the picture went but sound is still there. Can you give me an idea what it might be.
Posted on Oct 20, 2008
  • 1779 Answers
SOURCE: Purple band at top of tv screen
Please make sure you have the Lamp seated properly in the set. If you purchased just the lamp without the basket make sure it is Flush against the front of the lamp basket. The light path is being obstructed or not aimed properly. Let me know, hope this helps.
Posted on Feb 03, 2009
  • 184 Answers
SOURCE: sony grand wega 55in kdf-55a20
Its most likely an intermittent lamp. The lamp door is located behind the front panel. The front panel can be removed after loosening the two thumb wheels located on either end of the TV in the rear. Observe the light coming from the area around the lamp door. If you see that the light is going out, its the lamp. You can also access the self-diagnosis menu by using the remote control. Start with the TV off. Push the "mute", then the number 5 button, and then the volume down button followed by the power button. When the picture appears, the menu will been visable. If there is a failure with the lamp, or a fan, or many other areas in the TV there will be a number value to the right of the parameter that indicates the number of times the error has occurred.
michtech
Posted on Feb 16, 2009
  • 87 Answers
SOURCE: Sony Shadow on top of screen
Please call sony Optical Block warranty extended to June 30, 2010
Posted on Apr 14, 2009
  • 8457 Answers
SOURCE: Sony rear projection tv
How long have this tv had it picture bulb,change before for this tv?Longtime usage,picture bulb the first,must change.
Posted on Nov 03, 2009
Testimonial: "Thanks"
I have black line down right side of 42 inch hitachi lcd tv screen
You have a CCFL lamp that is failing in the panel, time for a new TV
Jan 22, 2018 | Hitachi Televison & Video
Color fades to yellish
click the magic focus buten first and if that dont work then take off the black screen that covers the front boton of the tv and u will see a littie black thing with 6 buttens on it torn the top right 1 just a littie with the tv on and see what hapens. good luck
Oct 04, 2011 | Hitachi 51F500 51" Rear Projection...
I have a Hitachi 60sdx88ba UltraVision Digital Projection TV @ the top of the screen a yellow swoosh 6 inches wide with a blue line 8 inches under it. On the right bottam a 3 appears. Double image on the...
You have a defect in the convergence circuit. Both chips will need replaced and possibly a resistor or two. Chip part numbers are STK392-110. Typical repair runs around $350
Bill W
integrityhomeworx.com
Mar 20, 2011 | Hitachi 43UWX10B 43" Rear Projection...
I have a hitachi 43FDX10B ultrascand HD rear
well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
Nov 29, 2009 | Hitachi 43FDX01B TV
Projection tv has 2 pictures split with 8 inches of black
IN THE MENU GO TO COLOR CONVERSION OPTIONS AND TRY THAT ,,ALSO TRY NEW CONNECTERS
Apr 24, 2009 | Panasonic PT-52LCX65 44" HDTV
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Hitachi 50 Rear Projection color TV
the easiest way is to turn the color all the way down to zero. Then notice the overall color of the screen, if it doesnt appear as a good black and white picture you will have to adjust the screens. To do that you have to remove the speaker grill cover and the small access panel, then depending on the chassis you will see a small square with 6 dials on it 3 on top and 3 on the bottom it will have screen stamped on it. adjust those 3 untill your screen appears the best black and white picture as possible. Now if your chassis only has 3 dials on the sgaure control box those are focusdont adjust them. . then the 3 CRT boards will have the dials you need adjust those for the best black and white picture. when your satisfied that you have a good black and white picture. then turn your color back up and adjust the tint.Let me know if you need more assistance.
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
