Question about Casio Exilim EX-Z57 Digital Camera
Also a battery proble?
Hm! Interesting! I also discovered that if you open the battery compartment with the battery there and touches the battery with your finger from one side to another (very slightly!) the cam turns on and off. That means... the battery doesnt fit the camera well and this might have cause the memory loss?
It is a mess of a camera. I think Casio should have said something about it. That website they have is a shame.
    President:
  • 2,761 Answers
There may be something more serious wrong with the camera, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, wipe both ends of the batteries with the cloth, and reinsert them into the camera. This clears the problem about 90% of the time - I hope it works for you.
Posted on Sep 09, 2009
Shutter will open but not close
Sounds like the camera is not getting battery current, since that is how it will act without batteries. Does the meter needle respond to changing light when switched on? If not, check battery polarity -- the + end touches the strip at the bottom of the battery compartment, the - end touches the battery cap. If that all checks out right, one of the wires connecting the battery compartment to the innards may be corroded or loose.
Sep 01, 2013 | Nikon FE 35mm SLR Camera
I have problems with the touch screen of my htc tytn2 with wm6.5 pro. It does not respond. When touched, it goes straight to arc switch.
First of all remove the battery and the memory card from the phone. Use a hair dryer to warm up the battery compartment so as to warm up the set lightly. Now replace only the battery after about 15 minutes back into the phone and switch on. If the phone boots up and comes alive with a touch pad working, then reset phone to factory settings, connect your phone to PC to have a virus scan . Also now have your memory card scanned for virus, remove files and format.
If however the fault stays then you might have to contact Service to have the software reinstalled.
Jul 14, 2011 | HTC Cell Phones
Water from the ac is leaking into passenger area
TOUCH DOWN with leaky ac into passenger compartment solved!
Discovered on left side of firewall of trailblazer a series of ac hoses leading into compartment. Bottom left area are 4 hoses and one drain portal. I removed drain stem 4" long and compress bottom of portal with finger and condensation started pouring out. A total of 2 quarts of clear liquid condensation came pouring out. Tested ac afterwards and drain portal is flowing freely underneath vehicle.
Jun 24, 2010 | 2004 Chevrolet TrailBlazer
Salter kitchen Scales Model: 1041SVDR won't turn on.
This sounds very typical of kitchen and postal scales. I know you don't want to hear this, but this basically means it is time to replace your scale with a better scale - perhaps no longer giving Salter your business..
Mar 20, 2010 | Health & Beauty
Change battery
If it is cordless, it has batteries. You can usually tell if the small red light is off on the bottom.
Most mice have the battrey compartment in the rear half of the top of the mouse. The rear half slides off. Something like this:
Yours will probably hold 2 AA batteries. If it is one of the smaller ones it may have the battery compartment underneath and take 2 AAA batteries.
Hope this helps.
Thanks for using Fixya.
Feb 09, 2010 | Logitech Cordless Mouse
How to change AAA battery in headphone. Can't see how to open it to get to battery slot.
I looked inside the ear cups and moved the fabric. All the searching finally turned up the battery compartment on the outside of the ear cup with the switch on it. After that, it was easy. I also found out that you could disconnect the cable. That was interesting, too.
Dec 26, 2009 | Bose QuietComfort 2 Consumer Headphones
Screen is gone after the phone dropped into water.
The best thing to do is try to recover your phone.But don`t get your hopes up, nearly every phone that gets in touch with water dies.
Open the battery compartment, remove battery wipe compartment and battery with kitchen roll.
Take all parts into a warm room and leave for 24 hrs.Then reassemble...fingers crossed for you!
Dec 22, 2009 | Cell Phones
I have a canon A520 Powershot camera . I have 2 problems, 1st, when i take a picture and view it on the LCD there are white lines going horizontal across the picture. The scon proble is, I put in a newly...
The battery issue seems to be a problem with this model after 4 years, unfortunately you have to open and close the battery compartment to clear this error. This is not a permanent fix.
Sep 03, 2008 | Canon Cameras
Samsung F700V shortcut display problems
Hm, this is a difficult one. I have a F700 and there is no option for it to auto lock on slide closure. U might have a different firmware so look around the settings for it. Disable it if you can find it.
This might also sound stupid but make sure the lock key on the right hand side has been slid up. Slid down locks touchscreen.
My f700 does NOT launch the camera upon pressing the camera button at home screen. It does nothing if i do that. I need to goto into the menu and then the camera for the camera button to work and to take pictures. I think this was a smart move for Samsung to design it like this. I could see myself accidently pressing that many times.
Jun 23, 2008 | Samsung Ultra Smart F700
I can't open the battery compartment
Had same problem. Try pressing the heel of your hand on the battery compartment lid and rotate. Worked for me.
Dec 27, 2007 | RCA WHP141 Consumer Headphones
Casio Exilim EX-Z57 Digital Camera Logo
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
