Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Cable Clutch 42in key number152part 169670 - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
    Brigadier General:
  • 5,158 Answers
If you need to know where to obtain the part give home depot a call
robert
please take a moment to rate this solution thanks
Posted on Sep 09, 2009
Poulan 18.5hp 42in cut deck 6 speed drive belt not broken woz loose but when i spin rear wheel the drive pully duz not spin if i hold it is the ckuth worn out or should this work like this
The clutch works on centrifugal force, so when the engine ticks over the drive is not engaged. As the engine speeds up the drive engages.
Oct 30, 2016 | Poulan Garden
WHERE ARE THE SAFETY SWITCHES LOCATED ON A 42in CUT MODEL #247.289010? (SEAT)(DECK)(CLUTCH PEDAL) ANY WHERE ELSE? THANKS S.N.L.
there will be one under the seat and if you have to lift a lever to engage the blades there may be one under that
Sep 06, 2016 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I adjust brake/clutch start on troy bilt 42in riding lawnmower
Sounds like a safety switch is not working right. Mine won't start unless I pull back on the handle that engages the blades. If I make sure that handle is pulled up as far as it will go it starts. I disconnected the safety for the seat because when I turned my body the seat moved and shut the unit off and its a new machine.
Sep 25, 2014 | Garden
Sharp Aquos LC-42D62U 42in hdtv lcd How do I get the channels to change faster? It's like a delay compared to my other hdtv
There is a 3-5 second delay between the channels when you change them on these particular tvs and there is no way to change that unfortunately.
Nov 02, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
INSTALLING CLUTCH CABLE ON CRAFTSMAN
the proper threading of cable clutch for 38 in. craftsman riding lawnmower model 271150
Mar 29, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My 1996 jetta 2.0 4cyl, won't start when pressing down clutch. I have to keep turning key, with some startup at times, by shifting gear shift. Can you help?
If it starts easy in neutral, then the clutch is "dragging" meaning it is slightly engaged. You can adjust the clutch cable at the gearbox end by holding the outer cable with a pair of pliers or grips, careful not to crimp the cable as you could damage it, and turning the serated plastic cap to tighten the cable. If this doesn't work then either the cable is already too stretched, or the clutch bearing is faulty and needs replacing.
Aug 03, 2009 | 1996 Volkswagen Jetta
Clutch cable adjustment
the clutch cables dont really adjust if its still to long after fitting a new clutch then i suggest that a new cable fitt4ed aswel as it seems to have stretched
May 29, 2009 | 1996 Ford Escort 4 Door
Clutch Cable
first remove it on the gearbox. when you have an automatic cable please buy conventional one. it its fixed with a kind of key push cable down and remove key. other side is just on a hook on the pedal under the steeringwheel goodluck
May 22, 2009 | 1991 Volkswagen Fox
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
123 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
