Question about RCA RCR660 Remote Control
Sanyo mts 25580 switching from channel to video
How can I switch my sanyo to use the rca jacks?
2 Suggested Answers
  • 4 Answers
SOURCE: unable to get remote to switch to tv/video RCA remote tv is sanyo
It took me forever to figure it out. Press the input key, just below the 9. The TV channel should be on 3. Make sure you put your DVD in and press play manually, so you can see that it is on.
Hope that helps
Posted on Apr 04, 2009
Sanyo dvw 7200 dvd only plays sound no video
It sounds to me as if you have the connectors (phono plugs aka RCA plugs--Yellow = video; Red = right audi channel; White = left audio channel) switched OR the yellow isn't connected.
Nov 19, 2010 | Sanyo DVW-7200 DVD/VCR
I have an old NEC TV, NEC MTS dbx Stereo reciever/monitor, from the 1980's. It has not be used in over five years and now I want to use it. Everything seems to work fine except I only get the first 14...
If there is no cable switch anywhere (make sure you check the back where the cable screws on) you will have to have a converter box to change channels with. When using a converter you put the TV on channel 3 or 4 and switch channels on the converter. Thanks
Oct 22, 2009 | Televison & Video
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
Unable to get remote to switch to tv/video RCA remote tv is sanyo
Hope that helps
Apr 03, 2009 | RCA 3-Device Universal Remote with...
Mts video switch
On the Sanyo remote there is a button TV/VCR. Press that button
Mar 15, 2009 | Sanyo DS31590 31" TV
Can't switch from aux to video.
The universal remote will not work because there has to be an input button on it.
Aug 24, 2008 | Sanyo DS13204 TV
It depends if you are using RCA jacks or coax . now RCA is the best way to go . its the wires that plug in to the back of the TV colored red ,yellow and white (yellow is video) (red and white is right and left audio). Now to get to the Question at hand. Either channel down on the rc600d. to the channels below 02 should find
(av )channel if not then look on the rc600d for the tv/video button and try this. make sure the ps2 is on. a blue light on the front of it will mean it is operating .
Jul 07, 2008 | Video Game Consoles & Games
Sanyo MTS TV
Most universal remotes should have a TV/Video button. Look carefully on the remote. Or get another brand remote.
Also depending on your Sanyo model there may be a TV/Video switch on the front of the set. Look for a possible small cover along the bottom.
Feb 26, 2008 | Televison & Video
Sanyo TV
I too just bought an RCA remote for the same television. The button to access other video screens is the A/B button on mine (next to the last channel button).
Jan 08, 2008 | Televison & Video
RCA RCR660 Remote Control Logo
250 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
