HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Posted on Sep 22, 2009
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
KENMORE ELITE WITH CATALYST FILLED WITH WATER AND WILL NOT DRAIN AND SPIN
REPLACE THE DOOR SWITCH . IF THAT DOES NOT WORK REPLACE OR CLEAN THE DRAIN PUMP..
Apr 25, 2017 | Kenmore Washing Machines
Won't drain or spin. after disconnecting power and resetting I set it to drain/spin and start. It clicks, a little water goes in, It clicks the door locks, it clicks the spin light comes on but nothing...
Clean out the pump filter and see if that helps.
SERVICE MANUAL
NOTE: Use the manual as a guide for replacing component. Use your machine's tech sheet for diagnostics then party on!
Mar 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washer will not drain
I would check the lid switch first using a pen open the lid set into spin and depress down on the lid sw if you dont hear it click then it is bad
Aug 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer
Im sorry to here the timer replacement didnt help
T
Jul 19, 2008 | Washing Machines
Frigidaire Washer/dryer combo
Dtronics,
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
handiman518
Nov 13, 2007 | Frigidaire FEX831CS Top Load Stacked...
Washer does not wash or spin
the electronic module who drives the motor its the problem . you can order and replace find part at partstore.com go by brand and model let me know if you need more help thanks
Jun 20, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
307 people viewed this question
Top Washing Machines Experts
