Question about Acer AOA150-1690 Aspire Notebook
This is a pink acer aoa150-1690
No power going to computer won't light up at all
  • 453 Answers
Check for the AC adapter lights.
If on.
Remove battery and try with AC adapter alone,
Remove Adapter and try with battery alone,.
Remove power cable and battery and press power button for 30 seconds.
Place battery and Ac adapter back in its place,
Check with a different power chord first and see whether it works fine.
If this does not help then the issue is with the other internal components.
You may want to remove the hard drive, memory and the Optical drive with the battery and the AC adapter out.
Even if this does not help then the issue could be with the main board.
Posted on Sep 09, 2009
My Acer AL2416W is showing a tint of pink in all images I try to display, I have changed the cables with no change. I have taken the monitor to a new computer and it works fine ( no pink at all ). Why is...
The problem is in your old computer, the video graphics card is faulty, you mentioned the monitor was hooked up to the new computer and worked fine.
Apr 17, 2012 | Acer AL2416W Monitor
Green light on. computer wont turn on
Unfortunately, if the light is on, but the computer won't power on, it means one of two things. Either the power cord is broken in some way and no long sufficient to power the computer, OR the motherboard is dead. You can try to purchase a universal cable from Best Buy for instance, and then return it if it doesn't solve your problem. A motherboard repair would be best done through Acer themselves, although, it can cost over $300.
Aug 23, 2011 | Acer Aspire 5735 Notebook
Acer Aspire 5538 Won't power up at all. I have charger in and plugged up, when I try to puch power button it clicks off. What can I do?
It sounds like your computer's charging port is disconnected from the motherboard. The charging port cable probably has to be re-soldered to the motherboard to be fixed. If you are not skilled in computer hardware repair-ale I would suggest going to a computer technician.
May 13, 2011 | Acer Aspire 5610-4648 Notebook
My acer Model X221WSD monitor screen is pink. I've tried
Pinkish back ground can be the sign of the lamps are going bad, but usually it will also cause the screen to go into shutdown mode also. Try New VGA cable or move the VGA connectors? Does the same on other PC?
Please post back so we can guide you further toi narrow down the problem.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 09, 2010 | Acer Monitor Lcd 19in Al1923 0.29mm...
My acer monitor X203w has a pink rather than white background. That is very annoying. It just started a day or so ago. Is there a simple fix?
The pick tint is caused by the backlights not going to full brightness. It is going to be either the back light tubes or the power supply/inverter board. Your monitor should still be under warranty with Acer so you need to contact them and get it serviced. The longer you wait the worse the tint will be until the monitor quits working all together.
Buddy
Corporate Computer
www.ccl-la.com
Jan 21, 2010 | Acer X203W 20" LCD Monitor
My acer X193w+ screen turns pink. What is causing
laurie515, Gee, I hope it's a 'pretty pink' colour. Do you really mean that What was once WHITE or VERY Lite GRAY is now appearing pink??? Laurie515 you must tell us more. How old is this unit? 4-6 yrs? I suspect that the "Cold-Cathode-Fluorescent-Tubes" that are hanging on the rear of the LCD glass panel and provide white light, have over time, now become tired out. YOU WILL NOT FIX IT!! IT WILL ONLY GET WORSE. Here are some options. 1. Trade in for new if yours is >4yrs old. 2. Check for swapout program with ACER? This is only a dim Maybe thing. You send them yours +$50-$100 and they return a refurbished unit. 3. Find local TV/Monitor Repair shop that knows all about LCD monitor repair. there are also guys on fixya that do LCD refurbishing (new ccf tubes/inverter/smps) Do some web searches on LCD monitor failures and also visit youtube for vid clips of monitor disassembly if you want to see the insides of a typical LCD monitor.
Bye for now. I'm louie12fix on fixya or lmistyrel@ aol.com
Sep 24, 2009 | Acer X193W LCD Monitor
Aspire 6930 computer. Will not do anything. Light is bluish pink instead of blue.. Please help!
My advice is to call the manufacture and see if its still under warranty or it can still be under warranty at the store you bought it from especially if you got a service plan extension. Usually if nothing happens it usually electrical. It could be as simple as a new cord (especially if there is a box in the middle), your power source could have blown. Worst case scenario your board burnt out. Here's hoping its just the cord. Hope this helps.Good Luck =)
May 30, 2009 | Acer Aspire 6930-6082 Notebook PC
The monitor is pink
Check and reseat the monitor signal cable. From the computer. If after reseating the signal cable the problem is exibited .It would require more inspection. Could you mention the model number of the acer monitor you are using
Thanks
Proton
May 29, 2009 | Acer Monitor
My Screen is pink
there must be some problem with the hardware of screen. get it checked from a professional
Jul 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer AOA150-1690 Aspire Notebook Logo
130 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
