Question about Samsung LN40A550 LCD TV
Ln40a5op3p Samsung LCD 40" stopped playing sound while whatching tv. Using the regular antenna screw in for cable on the back of the TV NOT the yellow red and white cord. Xbox works fine for sound but watching cable has none, the tv is not muted all setting for audio the tv has been reset to default via their settings, still no sound
  • 585 Answers
Hi my name is Eric,
I hope I can help you with your issue ,
Do you have a cable box?
 First thing i think of is you need to reboot the cable box by unplugging it from AC power, then reconnect it. (then reboot the Tv same way if haven't done that yet either) then its time to try it with AV cables
to make sure the cable box is not bad. using the red/white and yellow cables
then testing with another source like a DVD player, common sense will tell you if its the cable box or the TV.
If you've already done this or don't have a cable box (sorry),
The only thing in the TV that can cause you to lose audio only on TV is the SAP mode.
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Posted on Sep 09, 2009
Testimonial: "Great feedback with multiple options thanks"
  • Eric Rotmil
    Eric Rotmil Sep 09, 2009
    Also check with samsung, they have some firmware updates that you do to your TV with a USB flash drive for audio dropout
    thanks
    eric
Samsung TV model un40eh53000fxza have sound but no picture
It all depends on the connections and cable.
If you are using a HDMI cable and have sound but no picture, then your TV probably needs to be fix.
if you are using a RCA cable or component cable, make sure that you have the correct TV input.
you don't specify what type of TV you have, but if I were you, I'll check the connections first.
Aug 06, 2015 | Samsung 40" 1080p 60Hz LED-LCD Smart TV...
Channel setup
You may have to go back to the intial setup procedure and do a channel search.
Jan 06, 2014 | Mitsubishi LT40164 40 in HDTVReady LCD TV
Sound cuts off when whatching tv
This is common when you are using an antenna to receive a digital signal. When the signal isn't strong enough normally the first thing that you will lose is the audio. I would try installing an antenna or adjusting the antenna that you already have. If this does not improve the issue or if you are using satellite or cable television service, I would contact the provider. Rarely have I seen an issue like this where the actual television is the culprit.
May 05, 2011 | Televison & Video
No signal on samsung 40"lcd tv
IF it is an ATSC tuner ,newer type ,( digital tuner) it needs better antenna, most importantly Check the cable from Antenna to the connector. using multimeter , put on resistance ,any, anc check both ends of the cable, when there is no change on the multimeter consider the wire is broke somewhere. Make sure the antenna is pointing towards the tv station. also check www.antennaweb.org i think to see the DTV channels in your area. GL
Apr 08, 2010 | Televison & Video
I have a sony 40 inches bravia flat screen hd and
Could be the decoder:
1. unplug the TV ans wait a few mins.
2. If you have digital cable box or dish tuner reboot those as well (likely your issue)
What you have is artifacting what that means is tiling garbiling and freezing this happends when the data in the digital stream just stopped hence Frozen.
Try those things rule out your cable tv box first or your sat box, if this is OTA over the air your antenna.
1. Try DVD's if it happends during a DVD you do have a decoder issue if it does not you need to talk to your cable tv or sat operator.
So you got 3 possiabilites here 1. the worse Decoder, 2 cable company or satalite provider, 3 your antenna is in the wroung position.
I sure this will help.
Nov 30, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Screen is black on my Samsung LCD TV
Press your input button for the correct input your using for cable or viewing regular channels.
Apr 14, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Dec 31, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
Nov 05, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Help getting sound from New Sony LCD Television Model XV HTD520 DVD Player with Surround Sound S HTD520
While I could not find it in the manual, I found that you must
go to the menu, open Sound Options and set Speakers to "Fixed".
Note: If you turn off the Surround Sound or DVD player combination you must then go back to the menu and turn the speakers back to Televsion.
Jul 21, 2008 | Audio Players & Recorders
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN40A550 LCD TV Logo
166 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
