Question about Terminator 2: The Arcade Game
Guns on my terminator 2 cabinet dont aim at the targets???? they shoot from the bottom of the screen to the left slightly, so they work, but they dont aim??
Okay, behind the coin mechanism there should be two switches. The one on bottom is for service credits, the one on top should say "test" or "options", something like that. flip the top switch. The game should turn off and the options menu should appear, use the start buttons and gun triggers to select "calibrate guns", then shoot at the three targets with each gun. If that doesn't work, then the controllers themselves are broken. Not sure I can help you with that.
Posted on Mar 07, 2010
How to just read sights on my tanfaglio .45 . It is shooting low and slightly left.
In the case of a non-user adjustable sight, any adjustment should be entrusted to a qualified and experienced gunsmith, though few hand guns are superbly accurate and part of the skill of using a hand gun is to compensate for sight inaccuracies - knowing it shoots low and left then aiming high and right by the right amount is what it takes...
May 27, 2017 | Optics
How to fix an arcade screen on a big buck hunter safari machine?
If the screen appears discolored in the area where it does not shoot then it is possible that you have a degaussing problem( which should be fixed with turning off the machine for a half hour and then back on) or a loose shadow mask in the monitor( which you can do nothing about). Assuming that is not the case then try turning up the brightness and contrast beyond normal and see if it registers. The easiest way to do that is in the tracking screen. If turning up the controls works then you most likely have a bad capacitor in the monitor or on the circuit board. Another possibility would be background light bouncing off the screen. Turn out the lights in the room and try again. Good luck
Apr 27, 2014 | Video Game Consoles & Games
Does anyone have a problem sighting in a mosberg 935?
Shotguns don't "sight in" remember. Shotguns don't "aim". They "point". That's where patterning your gun/ammo comes in. Just get a variety of shells from diff manufacturers and start shooting at cardboard targets AT THAT RANGE YOU EXPECT TO SHOOT. If the spread is less than 50% pellets on the expected target at that expected range, go tighter on the choke tube until it is. Be warned....that one perfect brand of shell you find today probably won't be working so well a couple of years from now. Be ready to repattern in the next couple of years. Nice gun, btw! Congrats!
Apr 24, 2014 | Mossberg 935 Barrel Turkey Adj. Fiber...
If my left eye is the dominant one should I place the target more to the left or right?
It doesn't make a difference; you should try to train your eyes so the best thing is to keep both eyes open when shooting at a target.
Jan 17, 2013 | Sport & Outdoor - Others
Have nintendo scope 6 and able to do first screen but when it goes to test aim screen nothing happens just remains on screen
If the screen you see is a blue screen with a white target, you need to aim the Super Scope at the target, and shoot. This tells the interface box (the device you plugged into the SNES) where the center of the screen is relative to the Super Scope. If shooting the screen does nothing (does not continue the calibration routine by going to the aim test), your particular cartridge of Super Scope 6 is glitched.
Jun 25, 2011 | Nintendo Super Scope 6 for Super
Namco Ps1 Guns not working (npc-103)
You must be using on a plasma or LCD tv right?
Will not work... Only works on old tradicional TV...
Jul 26, 2010 | Namco Time Crisis: Crisis Zone
How do you set a center point scope
the way i tell the guys to set there scopes up is this,,,first clamp the gun in a gun vice, fit scope or in your case a center point,,,aim at the target down the barrel then fire the rifle at target card,,,(a big one) at no more than 20yds away, look for the strike mark,,,and without moving the gun at all, after firing the first round, move the scope so that the cross or center point is over the hole in the target,,,then repeat this lot again till you have the bullet hitting were you point the cross, all you need to do then is move the target back and lower thee point of aim on the scope as it should be shooting at the moon
Nov 10, 2009 | Crosman Optics
Sighting in, clicks don't move where they're supposed to.
Ja, it's 1/4 M.O.A, so at 25 yards/meter it'll be ca 3 inches. You may have gone in the wrong direction. That is, if it was 3' high, and you went another 3 higher then you'd be at the top of the paper. Probably you've got it figured out by now.
The easiest, fastest, cheapest way to zero is with a rifle rest you can clamp your scope into, or alternatively somehow immobilize your rifle some other way. You take a shot, at 25 yards or so. It makes a hole. You now immobilize the rifle, via your rest or heavy sandbags, with the scope pointing exactly where you aimed before. You now, carefully and without moving the rifle/scope off of the point of aim, dial your reticle to point at the actual bullet hole. Your next shot will be at your point of aim now. So you just put it at the right height above your point of aim at 100 yards now.
Nov 02, 2008 | Bushnell ® Elite® 3200 3 - 9x40 mm...
CROSMAN 760 PUMP PELLET RIFLE REPAIR
How do you change the air cylinder
May 26, 2008 | Crosman (4032)
Mad catz drteam blaster
dude im not so sure about this just one tip is dont ever buy madcatz stuff!! PLZZ!!!
i cant help sorry! :(
Dec 27, 2007 | Mad Catz Dream Blaster (7188) Light Gun
Terminator 2: The Arcade Game Logo
459 people viewed this question
Top Terminator Video Game Consoles & Games Experts
James Wishart
Are you a Terminator Video Game Console and Game Expert? Answer questions, earn points and help others
