Question about Kenmore 73952 Gas Dryer
Drum not rotating on kenmore 80 seires gas drier
Drum not rotating on kenmore 80 series dryer suspect belt is problem but how doyou get to it?
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Please post your complete model number (located on a nameplate around the door opening) so I can determine how your dryer is configured.
  • Kenmore Master
  • 8,220 Answers
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
Kenmore gas dryer drum does not rotate
The most probable cause is that your motor went bad....
Check out this tip...it will help you..
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 29, 2010 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
I have a used Kenmore Series 80 dryer & the drum stopped turning
Good day,
Not hard to do but check the 2 rear wheels that support the drum and change at the same time if needed. Inspect the belt tensioner as well.
Here's a good tutorial on the belt change.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 15, 2009 | Dryers
Kenmore Series 80 Heavy Duty Gas Dryer turns on but drum won't move - is this likely a belt problem? Dryer is about 12-13 years old. Model 75651
Good day,
Reach in, and see if you can move the drum. It will be a little stiff, but should turn.
If so, yes, it is probably a belt.
Look below. (Yes it is made by Whirlpool).
If hyperlink won't work, then copy and paste it in the address bar of your browser.
Dec 10, 2009 | Kenmore Dryers
I have a kenmore 80 series electric dryer. It gets
If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
Heavy duty super capacity plus Kenmore 80 series Electric drier the timer is running, but when I push the start button - nothing
the drum belt may be broken. you will have to check this, it goes around the drum and the pulley on the motor. you could also have a bad motor.
Oct 16, 2009 | Kenmore 73952 Gas Dryer
Kenmore 80 Series loud rattling noise
Its called a Drum Support. Purchase at any appliance parts supply store or online from Sears or Whirlpool.
Part# 3397588 or 349241T (Pk of 2)
Jun 08, 2009 | Kenmore 63942 Dryer
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore 73952 Gas Dryer Logo
380 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
