Question about Epson Stylus CX4800 All-In-One InkJet Printer
Used generic ink, won't clean and print
I have a CX4800 epson, and it has been wonderful Always used generic ink, but the last cartridges say they are remanufactured. I have used 5 new cartridges trying to "clean the nozzles". It just keeps trying but can only get a very bad print out. Some lines are completely missing, some are faded and some are a little darker.
Is there some other way to clean the nozzles without using more ink?
Am getting black streaks on my printouts from my EPSON Stylus CX4800. They are darkest on the margins of the paper but the lines are visible across the entire page.
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 03, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Can you still use the epson with only one full ink cartridge
No. You must have ink in all the Cartridges, and they all must be Genuine Epson Cartridges. pls read below:
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
Jan 31, 2010 | Epson Stylus CX4800 All-In-One InkJet...
I replaced the ink cartridge but it says out of ink
I received that same message when I was using Generic. Please read on.
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
Enable epson stylus CX4800 to only recognize black cartfridge and not color ones
for the Color Ones?????
Jan 28, 2010 | Epson Stylus CX4800 All-In-One InkJet...
R1900 adds blue-green tint to my photo prints
Epson doesn't like Generic Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
Jan 22, 2010 | Epson R1900 Printer
I just changed color cartridges and nothing is printing. The paper feeds and comes out blank
Go thru the panel to change cartridge. See if that help. Then turn off and wait for 15 min.
Jan 21, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Dx4800 printing black lines over ordinary print. tried cleaning heads etc and put new cartridges in.
Are you Using Genuine Epson Ink Cartirdges?//???
Hello, In Purchasing Epson's CX 5400, CX4800, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
Jan 21, 2010 | Epson Stylus DX4850 All-In-One InkJet...
I have an Epson CX4800 printer. I have changed all the ink cartridges, but still can not get it to print, it goes through the motions, but nothing prints on the paper.
Try cleaning the heads. This should get the printer cartidges unclogged so the ink comes out. Also are you using epson cartridges or generic. How old are they. If new or quality generic. Its probably the head needs to be cleaned go through that process 2 or 3 times as its much cheaper than new cartridges.
Dec 13, 2009 | Computers & Internet
Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
May 27, 2009 | Epson Stylus CX4800 All-In-One InkJet...
There are stripes through the whole page of what I'm printing
Hi, its the print heads are clogged up, couple of things to try, head cleaning would be the first option, right click on your printer status program ie on the bottom right of the screen the small icon, and you should find maintenance or head cleaning, try doing this a few times, print something out see if any change, if still no success, change the ink cartridge, if still no success last try would be http://www.supermediastore.com/cleaning-cartridge.html its a head cleaning cartridge to try and clean the blocked print head, if none of the above work you would be better replacing the printer as epson charges £75 + vat to repair any printer, the last time i tried to buy print heads at trade they were about £48+vat & delivery and is really a nightmare to fit with epson,most new epson printers seem to only last about 15 months on average but its the amount of money you can save through using compatible ink, as we only sell epson printers ourselfs and this happens with 99% of returned printers..
Happy New Year
John
Dec 31, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus CX4800 All-In-One InkJet Printer Logo
59 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
