Question about Frigidaire ATF6000ES Front Load Washer
Water at the bottom of the basin and it is making noise
Water at the bottom of the basin and it want spin
    Problem Solver:
  • 14 Answers
See if the strainer is clogged by the pump.
Posted on Sep 11, 2009
Loud noises in the spin cycles?
You may have some clothing or other items that have come loose and gotten caught in the top or bottom of the basin. One way to determine if this is the case if to empty the washer and manually turn the wash basin a few times in both directions to ensure that it spins freely. If it does not, then something is caught and needs to be carefully removed.
Hope this helps! Rate my solution!
Jan 05, 2010 | Kenmore 43042 Front Load Washer
Making loud banging noises. Sounds like something is inside, but nothing is. Something seems to be between the basin(?) and its casing.
It is very common for an item to get stuck between the basin and casing. You can drain the washer and spin the basin manually a few times in either direction. It should spin smoothly, but with some resistance. You may need to remove the front cover by typically lifting the top enough the loosen the front panel, then inspect the perimeter of the basin and the condition of the belt and motor. Remove anything that doesn't belong (i.e. a sock or zipper!)
Jan 05, 2010 | Kenmore 44102 Front Load Washer
Won't spin. makes loud noise when draining and won't spin the basin.
If this is a top loader there is a cupling that is made of rubber and a set of plastic parts that are between the motor and the transmission drive. The plastic has fingers that go into the rubber piece and the fingers shear off , the other end of the motor has the water pump on it so it will pump water out but do nothing else. you have to pull the motor out and replace the set and reasemble.
Oct 24, 2009 | Whirlpool Washing Machines
LG Fuzzy Logic
The load is "off balance"
check the vibration dampers are solid and the springs at the bottom of the tub are intact.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Frigidaire affinity not draining
The problem is that on the infeed side of the pump there is a catch/filter in the Hose/boot that will catch lint and coins (LOTS OF COINS) and will not allow the water to flow through to the pump. This will stop the cycle and prevent the tub from spinning and the basin will not drain.
to fix this turn your washer over and access the pump from the bottom. the boot can be disconnected from the wash basin with a phillips screwdriver, reach in the boot and pull out the plastic catch and empty the debri, reinstall the the catch after cleaning it and put the boot back on. Set your machine back upright and conncet all the hoses and plug it in. It should work. This is a easy job but it will take an hour or so.
Sep 20, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Hotpoint aquarius wd440g washer/dryer
Hi claire your problem is the pump braking down check to make sure there is nothing in the pump if you still cant get the door open pull the mains plug out and turn off the water valves red and blue take off the top of the machine and get a basin take the drain hose out and put it in the basin and bring the two down to the floor empty all the water out you should now be able to get the door open remember to check the pump and the bearings
Jul 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Frigidaire Washer won't drain water
My will start to cycle and then it will cease to spin. No grinding, no off balance noise-no spinning=no draining of water from tub/basin. Unplugged it for a full 4 minutes. Plugged it back in. Checked to see if washer was level-it wasn't. Made adjustments to ensure washer was level-EUREKA! washer finished cycle no problem. BOO-HISS! Two loads later, same issue as the first time-washer won't spin. Checked to see if washer was still level-it is, new issue-error coed E20 and all lights blinking. ANY suggestions?
Jun 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Loud Clicking noise only for the first 30-40 seconds of spin cycle.
You may have something caught in the pump impeller. I have found nails, screws, drill bits, paper clips and other small items that some how make their way past the wash tub and into the drain line. I would inspect the drain pump. Remove as much water as you can. Using a wet/dry shop vac to pull water through the drain hose is the best way to drain all residual water from the pump and drain lines. Remove the inlet line first and inspect the pump impeller. Chances are, you have something stuck causing the impeller to rub against it. If this has gone on too long, you may have some damage to the pump. I hope this is helpful to you.
Jul 05, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
