Question about HP PSC 950 All-In-One InkJet Printer
Paper too narrow , cannot print on letter - HP PSC 950 All-In-One InkJet Printer
3 Suggested Answers
rakeshpramod
  • 234 Answers
SOURCE: Paper
If you see this message on the front panel of the HP PSC 2210 when you are receiving a fax, check that the paper size is set to match the paper size in the paper tray. (You cannot receive a fax on 4 x 6 paper or on an envelope.) Checking the paper size setting
  1. Press Setup .
  2. Press the right arrow until you see 3: Basic Fax Setup .
  3. Press Enter .
  4. Press the right arrow until you see 4: Paper Size .
  5. Press Enter .
  6. Press the right arrow until you see the paper size that matches the size of the paper in the paper tray.
  7. Press Enter .
Posted on Aug 28, 2008
  • 124 Answers
SOURCE: paper too narrow error
Have it save-to-image instead of print-to-paper. That should make it happier.
You can then print it out later, re-sizing it to fit the paper you have to print on.
Posted on Jun 18, 2009
Mac 1200 ekg machine prints out an extra sheet of paper with every ekg
You have the printer set up for the wrong size to paper feed stock. It is probably set up for the Rest of the World A4 size paper instead of US Letter size. This makes the sensor pull another sheet as A4 is a tad longer, but a shade narrower. The sensors work by length.
May 13, 2015 | Medical
Code PC Load A4
This means that the printer is expecting A4 paper rather than letter size or whatever you are trying to use. Check your "Printer Options" on your computer and make sure that the appropriate paper size is selected. A4 is an international standard paper size that is 210 mm (8.27 inches) x 297 mm (11.7 inches) and therefore is just a bit narrower and longer than the American "letter" paper size.
To correct this, cancel the print job currently in the printer's memory, change the computer to the proper paper size, and send the print job again.
Jan 26, 2014 | HP LaserJet 4 plus Printer
Printer cartridges wont align says alignment failed and then paper too narrow
I request you to perform the steps below to align the cartridge:
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges. Recycle or discard the page.
Bypass the alignment :
Press and hold the Enter button, and then press Menu
Mar 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Paper to narrow?
To print into a paper that seemed narrow compared to the printer's tray size, just move the lock located at the paper tray. Press the "locks" and slide it to "enclose" the width of your paper. When you release it, it is locked in place so your paper will print just fine.
Feb 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
WHEN PRINTING - THE PRINTER SAYS TRAY 1 LOAD PLAIN PAPER, USE PLAIN EXEC INSTEAD? THE PRINTER IS LOADED WITH 8 1/2 X 11 LETTER SIZE PAPER.
You have the settinigs on the printer wrong. There are two things you need to do:
1. Open the tray and check that the paper guides are set to 8.5 x 11 (letter). There are both length and width guides in the paper tray, and EXEC size is quite a bit off from letter-it is more than 0.5 inch narrower than letter. It is also shorter than letter.
2. On the printer, use the settings button to navigate to the paper size. (The exact wording may vary; it's been a while since I worked on a 4050. It may be under print settings.) Once you find the paper size menu, configure tray 2-yes, I'm sure-to use letter size, any type. By the way, on HP lasers, tray 1 is the fold down tray on the front, tray 2 is the tray that will hold 500 sheets of paper and is the "drawer" that you load. Don't ask me why they use that numbering system.
Feb 11, 2010 | HP LaserJet 4050 Printer
My photo subjects seem to print "narrower" than they look on the screen. Like they have been squeezed vertically.Could it be paper-size? I'm using letter size. I work in windows
Question - which looks to have the correct proportions, the print or the screen?
There's always the possibility that your screen is stretching the image and the printer is printing correctly.
Oct 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper too narrow error
Jun 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Paper pickup not moving
Have you set the margins?????
If you push the left margin over, it may help.
Jun 08, 2009 | Konica Minolta magicolor 2400 Laser...
How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper
  1. Press Setup .
  3. Press Enter .
  5. Press Enter .
  7. Press Enter .
Aug 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
