Question about Kenmore 22422 Top Load Washer
MY KENMORE FILLED WITH WATER BUT NOW WILL NOT WORK
MY SISTER CAME IN AND PUT A LOAD OF CLOTHES IN THE BARREL. SHE TURNED THE SWITCH TO WHERE IT NEEDED TO BE. THEN IT STARTED TO FILL WITH WATER, SHE WENT UPSTAIRS , THEN A LITTLE WHILE LATER SHE CAME DOWN AND IT WAS STILL FILLED WITH WATER. ME AND A FRIEND OF MINE WENT DOWN TO CHECK ON IT, WE TRIED EVERYTHING WE COULD THINK, BUT STILL NOTHING. WE TRIED TO TURN THE DIAL MANY DIFFERENT POSITIONS AND IT IS JUST DEAD. I NEED HELP!!!! ANY ASSISTANCE PLEASE!!
  • 5,911 Answers
Check your lid switch.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A new lid switch or lid strike (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all them for the best price.
If you have questions, or need additional assistance, please let me know. Please post back with a complete model number (located on a nameplate around the wash tub opening) with your questions, so that I may be able to provide you with better assistance. I hope this is helpful.
NOTE: You do not need to bail or empty the wash tub to complete this repair.
Posted on Sep 09, 2009
KENMORE ELITE WITH CATALYST FILLED WITH WATER AND WILL NOT DRAIN AND SPIN
REPLACE THE DOOR SWITCH . IF THAT DOES NOT WORK REPLACE OR CLEAN THE DRAIN PUMP..
Apr 25, 2017 | Kenmore Washing Machines
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
Jun 21, 2012 | Kenmore 43142 Front Load Washer
Product = model 15962 Problem = really bad smell
A good trick that i found was to fill tub with hot water and put a full cup of dishwasher detergent any kind but has to be powdered not liquid detergent. Do this two times in a row and then every month.
Jun 10, 2011 | Kenmore 15962 / 15964 Top Load Washer
I have a Kenmore Series 70 Super Capacity washer. The model number is 110.23712 200 (which doesn't seem to be a valid number when I do an internet search, but is the number on the plate on the unit). I...
Getting Sears parts 110.23712200
I will tell you what happened to me. One day my water valve quit. On that veryday my sister in law paid her weekly visit to wash her and my BIL's clothes. She bypasses 5 laundry matts to get here. I tell my wife we should not have a $75 water bill. So the water would not fill in the washer. I told her to get a 5 gallon bucket and fill it up then see how many buckets it took to fill the washer. 7 buckets later the washer kicked in and started doing it's thang. 35 gallons of water to wash a full load on highest level. Then 7 more buckets to do the rinse. 70 gallons of water to wash one load of clothes. I figured I had her cured from coming over every saturday just to wash clothes. But she found out I fixed it. LOL She has a washer and dryer at her house but IF she goes overs a certain amount she uses then the trailer park charges her extra for water. Soo she comes ta my house. Sweet.
Mar 11, 2011 | Kenmore Washing Machines
Barrel fills up but does not empty
Barrel -ok, your tub is full of water, check the lid switch. If it is not the problem you will have to give more information........To get at the lid switch you have to rotate the control panel up, it is either fastened with screws in the back side of the end caps or you push in to release some spring at the base of the end caps of the panel. Usually there are three wires to a lid switch, the center is the ground with the outside two being hot and neutral.
Jan 14, 2010 | Kenmore 22422 Top Load Washer
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Mar 13, 2009 | Washing Machines
Kenmore 90 model 110.20912991 wont stop filling with water
If it continues to fill turned off or even unpluged, It needs to have the water valve replaced it is sticking open.
Jan 27, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
41 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
