Question about RIM BlackBerry Curve 8310 Smartphone
Can no longer save photos
Error message: Ciphering material not found.
How do I fix?
  • 2 more comments
  • sdvallance Sep 09, 2009
    how do I re-format the memory card? It is only about 3 months old. Pictures won't save to the internal memory either. Would that make any difference?
  • sdvallance Sep 10, 2009
    thanks. That worked great
  • whatcity225
    whatcity225 May 11, 2010
    Go to www.blackberry.com/suppot and search KB10527. The instructions are there. They are too long to post here. Hope it helps.
  • whatcity225
    Sounds like either the memory card needs to be re-formatted or replaced.
  • 81 Answers
You are welcome, any time.
Posted on Sep 10, 2009
Error code: 369000
Hi there!
Error code 369000 on the DSi is a photo upload error from trying to upload a photo to Facebook. This feature in the Nintendo DSi Camera application has unfortunately been discontinued so there is no way to fix the error, you will no longer be able to upload photos to Facebook from your DSi directly.
If you still want to post the photos you've taken on your DSi you can save them onto your sd card, then plug the sd card into your computer and post them from your computer.
Have a fantastic day!
Jul 07, 2014 | Nintendo Dsi XL Midnight Blue - Utlsbka
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Ciphering
Ciphering is mainly caused due to old sim cards.There are two ways in which youo can solve this
1)Remove your sim and insert it again and see if the problem persists
2)Go to the customer care center of operator that provided you with sim card and demand for a new sim with the same number.You'll get this for free and insert it and enjoy.
Feb 06, 2010 | Sony Ericsson W550i Cellular Phone
Ciphering not provided by operator insecure transmission
Ciphering is mainly caused due to old sim cards,remove your sim and reinsert it.If the problem still persists,go to the customer care center of the operator and ask for new sim with the same number ,you would probably get this for free .Insert the new sim and see to it that the problem is gone now
Jan 13, 2010 | Sony Ericsson W800i Cellular Phone
F drive error Ox80070052
Reboot. Open Windows Explorer (Win key + E). Insert drive. Does F or any other drive become available?
Jan 03, 2010 | HP Computers & Internet
Ciphering is not provided by the operator,Insecure
There are two things that you can try and one of this definetely works out ,and the main reason beehind ciphering is old sim cards .
1) Try removing your sim and inserting it again ,check if the problem is resolved.
2)If the problem still persists, go to the customer care center of your operator and demand for a new sim in place of your old sim ,you should get it for free.
Nov 06, 2009 | Sony Ericsson W200i Cellular Phone
Ciphering
Receive photos through blackberry curve,on my whatssapp account
/uploads/images/6_25_2014_9_35_30_am.jpg
Jul 11, 2009 | Sony Ericsson K530i Cellular Phone
''cipering not provided by operator.insecure connection.''on W700i
May 31, 2009 | Sony Ericsson W550i Cellular Phone
"Ciphering not provided" error message
hi
this happens wen u have an old sim card, try 2 get a new sim card with the same number.
but save the contacts b4 hand, coz u have 2 save them on ur new sim card, and dont worry uur balance will be carried forward.
i hope ur prob has been rectified.
all the best
Mar 07, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
Ciphering problem
Aug 27, 2008 | Sony Ericsson K550i Cellular Phone
RIM BlackBerry Curve 8310 Smartphone Logo
116 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
