Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
MacBook Pro gives "BSD process name corresponding to current thread: unkown s on stack" message and starts beeping 3 times in succession. Tried booting from CD; it ate CD and won't eject. Continue to get register keys and the above message.
  • lrutledge3 Sep 09, 2009
    Haven't added memory. Discovered startup problem after leaving MacBook on, leaving for work, came back home, and computer was off. When starting up, experienced this strange startup behavior. With those symptoms, could it still be related to memory getting unseated?
    Brigadier General:
  • 5,158 Answers
Have you added memory to your computer recently ? you need to remove the ram and reseat it. if that does not work remove the ram and swap the slots for each stick.
robert
Posted on Sep 09, 2009
  • Roberta Smith
    Roberta Smith Sep 09, 2009
    here is the procedure for that
    http://support.apple.com/kb/HT1651
  • Roberta Smith
    i would reseat the memory as that appears to be an issue (3 beeps). there is a slight chance the memory has failed. have you added or removed any programs recently ?
Codigo 05.283 xerox 7655
El manual responde que la DADF onde escanias tus papeles tiene un sensor malo adonde se sale el papel.
Esto es para la WC7655?
005-283 RAP
BSD-ON: BSD 5.2 - Document Stacking
DADF Stack Height Sensor Logic Fail.
Jun 14, 2016 | Xerox WorkCentre Pro 765 Laser Printer
Macbook pro 13 three short beeps black screen
something wrong with the RAM I think, either not mounted well-check -or the wrong kind of RAM -or a bad RAM socket:
3 beeps on start up macbook-pro-13-three-short-beeps-black-abadwnk1mj4brvvpzp1wcyyy-4-0.jpg
Feb 20, 2013 | Apple Computers & Internet
My 13 inch mid 2012 MacBook Pro won't turn on. It beeps 3 times and a small light with each beep.
okay firstly look at the following links
http://support.apple.com/kb/ht1618
http://support.apple.com/kb/HT2674
Please give me feedback.
Regards
Dec 21, 2012 | Computers & Internet
Macbook pro won't turn on
have you tried using a restore point? or resetting it to factory settings, although I wouldn't do that until you are left with no other options....You can try to call the company and see if they can walk you thru fixing it.
Oct 16, 2012 | Apple MacBook Pro 13
Cant connect Macbook to Bose Soundlink Wireless Music System
What I did to connect to BOSE wireless speaker to my MacBook air was go in advance settings and uncheck all three options there and then press the wireless button until it beeped--> then I was able to pair it to my laptop. Success!
Jan 02, 2012 | Bose SoundLink Wireless Music System...
We don't know how to retrieve out messages from outside the house.
To play back messages remotely, first you'll need to have set up your two-digit security code (PIN). You can download a copy of the manual here which gives all the details. Once you've done that, here's how to use the system:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds. The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
3) Enter a command within 15 seconds. Each command thereafter must be entered within 2 seconds. These are the available commands:
  • 0 then 1 Repeat a Message*
  • 0 then 2 Playing incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop**
  • 0 then 8 Greeting Message Record/Stop**
  • 0 then 9 Answer System Off
  • 1 then 0 Help
* For the Repeat a Message function, press 0 then 1 within about four seconds to repeat the previous message, or press 0 then 1 after about four seconds to repeat the current message.
**For the Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, press 0 then 7, 8 or 5.
4) After the command has finished, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart above.
5) Hang up when you're done.
Jul 05, 2011 | Uniden TRU8885 Digital Answering Machine
I have a new macbook pro. I am using neatgear box (time warner cable) to get wifi. My macbook either a) won't find my wifi, b) will see my wifi and give full bars of signal but won't load pages or c) will...
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop/desktop/MAC about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Apr 24, 2011 | OEM Systems BRAND- NETGEAR. WIRELESS...
I have my mfc-240c already loaded as default printer on my pc, and am now trying to load the driver onto my macbook pro. I no longer have the manual. It is asking me for the node name and I have input...
You can find updated drivers and the manuals for your printer here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc240c_all
I suggest you remove the current drive , download and install a new driver for your Macbook Pro to see if this makes a difference.
If necessary the website has an extrensive Troubleshooting section that may be of assistance.
Mar 07, 2011 | Brother MFC 240C All-In-One InkJet Printer
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
46 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
