Question about Cell Phones
LG ENV vx9800 displays Camera Start Error when I try to turn the camera on, then goes back to the main screen.
I have an lg cosmos touch. When I turn my camera on it loads for like two or three seconds then this thing pops up it says camera start error. I've tried turning it off then back on again that...
RESET YOUR MOBILE TO FACTORY DEFUALT BY TYPING THE CODE BELOW ON YOUR MAIN SCREEN:
2945#*#
AFTER YOU TYPE IT ,MANY OPTIONS WILL APPEAR ON SCREEN,CHOOSE FACTORY RESET
Jun 03, 2011 | Cell Phones
Camera shuts off even with new batteries
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon.Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jul 12, 2010 | Canon PowerShot A95 Digital Camera
When i turn the camera on, the lens goes in and out, and then there is a message on the camera saying, "Turn the power off and on again". I do this and I still get the same error message.
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
May 11, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Lg Env Touch on front screen keeps turning a
my best friend and mine does that too
all of them do it
all you have to do is open it and close it back and it goes away it doesnt hurt the phone at all
Feb 28, 2010 | LG enV Touch VX11000 Cell Phone
Camera start error on lg dare
This is a software fault with the phone - restore your phone back to factory setting OR do a master reset on the phone (all data will be erased) and that might troubleshoot the issue otherwise take your phone back to Verizon and they will either fix the phone or replace it with another one.
Jun 23, 2009 | LG Dare VX9700 Cell Phone
Wont turn on - goes to black screen w/ "Verizon Wireless" Logo
its the short circuit in main board chip ic number IC431 OR IC436 check out .that faulty ic needs replacement.
Mar 05, 2009 | LG enV VX9900 Cellular Phone
Camera start error
Basically, the camera connection between the phone and camera have either gone bad or became disconnected. If it is under warranty, I highly suggest to get it replaced by either the service provider or the manufacture themselves.
Jun 13, 2008 | LG enV VX9900 Cellular Phone
Main display went black on enV
Yeah same with mine... the front screen went black.... it started to get lines up and down... then all of a sudden just the front screen turned off! :-(
Jun 02, 2008 | LG enV VX9900 Cellular Phone
Camera Problem
probably have to get a new one
Nov 20, 2007 | LG VX9800 Cellular Phone
White display on VX9800
The display contains of two main supplies. One is for the data which gets displayed on the screen and the second one is for a thin sheet containing the led's for light. It appears the the data connection has been lost. It can be due to a loose connection for complete malfunction of the screen. If the connection is not loose then the screen needs to be replaced
Apr 12, 2007 | LG HBM-300 for VX9800 Wireless Headset
Cell Phones Logo
317 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
