Question about Casio Exilim EX-Z57 Digital Camera
The same problem
I am so upset with CAsio... in the official page they ask to format the internal memory. It hasnt solved anything here.
While I was formatting for the 100th time, I decided to pick off the battery, so then I had an (internal) card error. The thing is. EVEN with the internal card error, the cam would turn on and ask for me to set up language and time. The card error was then solved when I pressed menu and asked to again format the card.
But I still have the problem and it is now proved that formatting the internal memory has NOTHING to do with this problem
I am still waiting for a solution. It is the 3rd Casio that I have, and it will be the last one. I am really upset.
informatica
  • 1114 Answers
SOURCE: Casio Exilim EX-S600 time and date entry at every startup
Even casio seem confused by this question! It seems that the camera will loose it's settings if the battery is dead or the camera is not connected via USB. Even if the battery is charged it could loose the settings within 24hrs. You can get the manual below: http://world.casio.com/qv/download/en/manual/
Posted on Aug 05, 2007
SOURCE: Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Posted on Dec 15, 2007
SOURCE: Casio Exilim Z57 Date and Language set up
OK, here's the fix. This camera has internal flash memory that is used to store settings and can be used for limited picture storage. Its use for saving setting is essential, however. If this gets corrupted then the camera won't save settings. Whoever said to format the internal memory had the right idea.
After much experimentation here's how. Remove your SD memory from the camera and turn it on. This will force it to run on the internal memory only. Run through the time/date/location setup again. It will complain about the memory card. Ignore this and press menu. Under Setup, select format. Choose format memory card and do it. This will format the internal memory. Once it is done, turn the camera off and back on. You'll notice that the problem is gone and it has remembered your last setup.
BTW, my camera is a EX-Z75. Not sure there is a Z57 model.
Posted on Apr 09, 2008
Larrysito
  • 73 Answers
SOURCE: Exilim memory locked
its or child lock ,check manual or firmware damage ....software in the camera check how to fix in manual..
Posted on Aug 30, 2009
  • 11967 Answers
SOURCE: Every time I turn on my Casio EX-Z75 camera it
Here's the toll-free tech support number at Casio...they should be able to give you an answer: 1-800-435-7732
Posted on Mar 02, 2010
MUSIC I MOVED FROM COMPUTER TO SD CARD WILL NOT PLAY ON CELVIANO AP620 PIANO
http://support.casio.com/pdf/008/AP620_6_E_1A_web.pdf
E-48
Using a Memory Card
You can use the procedure below to play back a user
song (page E-24) stored on
a memory card without
loading the song into Digital Piano memory.
Memory Card Folders
Formatting a memory card on the Digital Piano will
automatically create the four
folders shown below. You
put playback song data into any one of the folders. You
can use the four folders to group your music data by
family member, genre, or some other categories. Use
buttons
through (folders) to select a folder.
1.Store the music data you want to play back in
one of the memory card folders.
2.Insert the memory ca
rd into the Digital
Piano's memory card slot.
3.Press the (CARD/INTERNAL) button.
4.Press one of the folder selection buttons (
through
) to select the card folder you want.
This will display the song number and song
name of the first song in the folder you
selected.
5.Use the (w,q) buttons to select the
song you want.
6.Press the (PLAY/STOP
) button.This will start playback.
•Each press of (PLAY/STOP) starts and stops
playback.
•Fast forward, fast reverse,
tempo changes, and other
operations are the same as
those during playback of a
user song in Digital Pian
o memory. For details, see
"Playing Back a Specific
Music Library Song" (page
E-24).
7.
To quit memory card data playback, press the
Dec 07, 2013 | Casio Celviano AP-620 88-Key Digital Piano...
How do I delete pictures from a coolpix S4000
To delete individual pictures: while viewing the picture, tap the trash can icon on the screen, then tap yes when it asks for confirmation.
To delete all pictures on a memory card: format the card. TAP MENU, tap the wrench icon, select "Format card."
To delete all pictures in internal memory: format internal memory. Tap MENU, tap the wrench icon, select "Format memory."
The delete instructions are in the "Deleting Pictures" section of the manual (page 33 in my copy). The format instructions are in the "Format Memory/Format Card" section of the manual (page 150). If you need a manual, you can download one from the manufacturer's web site at
http://support.nikonusa.com/app/answers/detail/a_id/16763
Jul 16, 2011 | Cameras
My camera says memory card locked bbut my mermory card works in my sisters camera what do i need to do?
Remove your memory card from your camera. There is a button on the side of the card. Slide it the opposite direction. PROBLEM SOLVED!
Aug 06, 2009 | Casio Exilim EX-S500 Digital Camera
I need all data erased from internal memory i have tryed going to format memory to delete but it hasnt deleted anything
Do you have your card in? When the card is in the carmera, (most) all functions apply to the card.
To format the internal memory, just take the card out and try it again.
Rob
Dec 11, 2008 | Nikon Coolpix 7600 Digital Camera
Delete
You can just format the camera. There are 2 instructions, formatting internal memory and the other is when a memory stick is installed.
Just follow pages 46 and 47 from this official guide from Sony - http://www.docs.sony.com/release/DSCS600.pdf
Hope this will help.
Nov 08, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Wrong Manual Received for CASIO Pathfinder PAS 400B 2632
I was having the same problem, so I went to casio.com and looked for their manuals for watches. I ended up finding this page:
http://world.casio.com/wat/download/en/manual/
If you enter the number from the back case of the watch, (in this case, the PAS 400B is 2632) and it will allow you to download the manual from their archives in a pdf format.
Hope this helps!
Jun 10, 2008 | Watches
Samsung s1050 says file error
Are you able to transfer the images to the computer? It looks like a memory stick problem.. If your camera has internal memory then pull out the memory stick and save images to internal memory.. If the pictures are alright then you have to replace the memory card.. Do not buy them on ebay. 60% of the times you get fake stuff over there..
Mar 26, 2008 | Cameras
Camera is blocking card
What does your camera do when you try to format the card? Casio only recommends using Sandisc, Toshiba and Panasonic memory cards. I dont believe that there is a firmware upgrade available for your camera that would fix what is going on. Try formatting your memory card first and hopefully that will make it able to save on your card instead of internal memory.
Jul 17, 2007 | Casio QV-R41 Digital Camera
Jun 14, 2007 | Casio Exilim EX-Z57 Digital Camera
Does not read memory card
Casio only tested 3 cards with the camera. Sandisc, Toshiba, Panasonic. First: Format the internal memory of camera and then reset camera. In rec mode press menu go to setup tab go up to format press right arrow highlight format press set. Follow same steps for resetting. Then insert mem card and format mem card. If that still doesn't work I would say there is something wrong with the camera itself and would need to be sent in.
Jan 24, 2007 | Casio Exilim EX-Z57 Digital Camera
Casio Exilim EX-Z57 Digital Camera Logo
118 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
