Question about Creative Labs Zen Sleek Photo MP3 Player
Xen Sleek Photo
My Zen froze on a song. I rebooted it. It rebuilds the library fine but it still frozen on the same song. Ive rebooted many times but still the same thing. Can anyboby help please?
    President:
  • 4,402 Answers
Remove the song and add it again.
Posted on Dec 10, 2007
Creative Zen Freezes on Rebuilding
My Zen locked when I turned it on. It wouldn't play the track the screen was on so I pressed the reset button and turned it on again. It was then still locked on the same track so I tried turning it off which then froze as it was shutting down. After another reset it went through the rebuild screen then locked again. I then used the above fix (pin in reset, then hold play and power switch down). Taking me into the kind of bios screen I formatted the contents. Then added my library again. It's now working fine.
This is the second Zen I've had because the first one had the same problem so I took it back without trying to fix it. Both times the problem occured when I had my Zen plugged into my car stereo auxiliary jack whilst switching the ignition on in my car. I can't understand why this would cause the problem but I'll avoid doing that in future.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Creative Zen Micro (6gb) is frozen
Take your battery out of the back, turn it back on and let it reboot.
Jul 28, 2008 | Creative Labs Zen Micro MP3 Player
My Zen Freaking Froze Up!!!
Reset button to left - use a paperclip. If its a 4gB it might be faulty.
Apr 27, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen V Plus Frozen on the product title screen
this helped me as after it rebuilds the libary then it always froze on a song let the battery run out!
this worked for me straight away and i had tried loads of other ideas this actually came from the tech guys !!!
  1. Detach the player from the PC if it is connected, and turn off the player.
  2. Press and hold the Play button while powering on the player.
  3. When the player displays the Creative logo, release the Play button
  4. Select Format (All) and select Yes to format the player.
  5. After the player has finished formatting, select Reboot.
  6. Re-transfer the tracks to the player.
Feb 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative zen v problems-frozen
I Recently bought a Zen, and it works great. The only problem I found was that it freezes itself from time to time, and the best solution to this problem is on the bottom of your Zen, there is a very small Reset hole. With a needle or a toothpick, gently stick it in, and push lightly. This will allow the Zen to unfreeze, and return back into it's regular mode. All your files will be saved, and kept on to the Zen, so you don't need to worry about losing any of your files.
Any additional help, I'll be glad to answer!
-bananaboy101
Dec 04, 2007 | Creative Labs Zen V MP3 Player
Zen frozen
Go to recovery mode, and do a disk clean up. If that doesnt work, then you might have to format it.
Did you reset it properly? To reset your zen, put a pen head in the hole under the power button for 20 seconds
Mike
Nov 08, 2007 | Creative Labs ZEN V Plus MP3 Player
Not rebuilding Library all the way
1. Press and hold the Play button while powering on your player.
2. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Oct 27, 2007 | Creative Labs ZEN SLEEK MP3 Player
Been frozen for about a week
You have to hit the reset button. You stick the end of a small paperclip or even the wire part from those garbage bag twist-ties into the reset button which is the hole on the bottom of the player. As you push the paperclip into hole you must hold down the PLAY button. This should put it into the Recovery screen or else it will just say "Rebuilding Library". If it goes into the Recovery screen you select CLEANUP and then YES. After it goes through cleanup which can take forever then it will will usually reboot on its own or if it goes back to recovery screen hit REBOOT after you have done CLEANUP.
Jul 28, 2007 | Creative Labs ZEN SLEEK MP3 Player
Frozen/won't turn on??!!!
Apologies if this answer is offensively obvious. Try putting a paperclip or equally small object into the little reset hole at the bottom of the player if you haven't done so already. Mine froze a couple of times and it always worked.
May 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
Froze in the middle of a song.
Thank you thank you thank you a billion times, you just saved my life (well, at least my zen's). Did as you said, my Zen Touch 20GB is rebuilding it's library right now. Oh, now it's done. Everything's still there, awesome. Thank you!
Mar 03, 2007 | Creative Labs Zen Touch MP3 Player
Creative Labs Zen Sleek Photo MP3 Player Logo
99 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
