Question about Mitsubishi WD-62525 62" Rear Projection HDTV
T.V.powers up I get light blue screen then shuts down mits.wd-625
I am on my second bulb you can see the bulb light up it last about 20 seconds then t.v. turns off red steady light the first time it happend screen was like scrambeld cable screen went green then blue then off bulbs are not cheap 2004 mits.wd-62525
    Problem Solver:
  • 8 Answers
Not bulb component is damaged in power supply serction shutting down to protect other components
Posted on Sep 09, 2009
Turns on with snow and yellow light under lamp. Why does it shut down after 20 seconds?
yellow steady light is overheating. you have a stuck fan or its all clogged with dust. The only way to fix it is to find what is causing it to overheat or prevent the fan from spinning. It is not lamp related unless you bought a lamp that does not have an Osram bulb inside.
Sep 08, 2015 | Mitsubishi WD-65734 65" HDTV
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
Blue screen and steady green status light.
mitsubishi will rebuild the chasis for $200 with a 6 month warranty
mits.parts 1-800-553-7278
fax 1-706-654-4299
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
KDF E60A20 screen goes blank loses sound for 10 60 seconds
I've had this same problem ongoing for a couple weeks. Finally, tonight it would shut off every 20-30 seconds, stay off for another 20-30 seconds then come back on. It turned out to be my bulb. I blew the TV out with compressed air, removed the bulb and disassembled it. Taking the bulb out of the plastic cage I then remove one of the metal screens at the top of the bulb, it just has little clips holding it in. I took a bottle of rubbing alcohol, some Q-tips and proceeded to clean the inside of the bulb through the screen hole. After cleaning the inside I put the screen back in, cleaned the outside of the bulb with a rag and alcohol, then reassembled everything. The TV is much brighter, I had to turn down the brightness setting and has been running the last few hours without an issue. You can avoid all this by buying a new bulb but I don't have the money right now to replace it and I'm cheap so I'll milk this bulb for everything it has. Heat kills bulbs so if you clean the screens and blow out the TV once every couple months you'll get a lot of life out of it..... I'm almost to 4 years on my original bulb and my TV is on constantly!! Good luck to all!!
Mar 15, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Mits TV blue Screen
I fortuneatly bought a 4 yr warranty from Best Buy on my Mits. same thing happened with the blue screen fuzzy white diamond. The geek squad techie showed me the 2 capacitors that go bad on the power board and he ordered them and once they were replaced the TV worked perfect again. I have 2 weeks left on the warranty, so i'm calling them today to get my last free bulb(screen is kinda darkening, kinda) hopefully i can convince the technician. This was one warranty that bad for itself.
if you have any electronic skills you can replace these capacitors yourself, once you get into the guts of your unit.
Good Luck
Oct 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I replaced the burnt out lamp,not working !!!
This may sound crazy. If you still have the old lamp. Put new lamp in old housing, and try that.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
309 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
