Question about Reddy Heater-40,000 BTU Kerosene w/T'stat
(ready heater) won't start or starts and goes out after 30 seconds of running.
It seems like it is getting to much air, i cover the inlet or slow the inlet air down and it will run. We hve had the hood off and it will run w/o any problems. We are lost . Can someone help? We have drained the tank and washed it out. Nothing unusual came out. the filter was changed when we cleaned it. we didn't mess with any of the adjustments (air or filters).
  • Anonymous Dec 22, 2008
    heater code says c3 no ignition
  • twobons Jan 02, 2009
    I have a 60,000 and a 100,000 ready heaters and they both start but wont stay running. I cleaned air filter and checked fuel filter,only a plastic stem!?? on the 60,000 one and no change.
  • 625 Answers
Air pressure to the nozzle shouldn't be more than 3.5 psi.
Posted on Dec 11, 2007
My 50cc scooter won't go over 30mph
Hi, Bob and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichener valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper float level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Help Ruck won go above 30mph Thanks
Advice please 49cc won go over 20 mph
gy6 50cc to 100cc bbk upgrade still wont go over 30mph It Is The Ride
My scooter won reach top speed anymore scooters
SCOOTER WONT GO OVER 20MPH HELP
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 28, 2017 | GAS Motorcycles
I have a 2006 Cobalt when I start it something always sounds like a fan runs after the engine runs for about 30 seconds and whatever sounds like a fan running only stays on for about 10 seconds. Can you...
I suspect that it is the operation of a viscous fan hub. Check this by placing your finger on a blade and seeing if you can spin the fan with the engine stopped. It operates when the engine is started and pumps silicone fluid from one side to the other inside the hub and when it has done so the fan slows down in relation to engine speed . Hence the fan noise on starting and then after a short period the fan noise goes away. It will start to operate again when the engine temperature starts to rise when you are stopped at lights or idling for a while to draw air through the radiator to cool the coolant and when you start moving and air is passing through the radiator again it will slow down. If you experience engine overheating while idling have it replaced as it is not pulling enough air through the radiator to do the job
Nov 30, 2013 | Cars & Trucks
I have a Challenge GBV180 Garden Blower Vacuum. I can only get it to blow ..does this model vacuum and if so how do the bits attach ?
remove the blower tube by turning anticlockwise. remove cover from air inlet same way. attach large diameter suction tube to air inlet (has to fit correctly as this is where the safety switch is) attach collection bag to air exhaust opening (where you removed the blower tube from)
Oct 15, 2010 | Garden
Freelander 1.8 stalls from start,then runs fine
change the air idle valve on inlet manifold.
Apr 30, 2009 | 2002 Land Rover Freelander
Heater turns on for a few seconds then goes out
Absolutely K1 or diesel can get old in a hurry, the ultra-low Sulphur diesel has been tinkered with so much that it turns to book varnish much faster than before 2010. Most of those heaters spray fuel past the igniters using a siphon much like a spray paint gun, the suction tube may have dry rot or a small air leak and it it takes but a tiny air leak to kill the siphon effect. Check the tube from the nozzle all the way down to the fuel tank or replace it if you're not certain it is not compromised or dry rotted.
Oct 12, 2017 | Reddy Heater-30-55,000 BTU Variable
Ticking in engine on start up
loud on startup and gone in 30 seconds sounds like a lifter that had de-primed, it can run this way for a long time. what weight oil are you running?
Mar 25, 2009 | 1997 Chevrolet Blazer
2001 Dodge Caravan SE 2.4L.. In cold Weather it starts then stalls and dies...?
cable is fine,can be the tps but try tapping on the idle air valve and see if the idle kicks up,it works like a choke and if its stuck its a big vac leak
Nov 05, 2008 | 1990 Dodge Caravan
Reddy Heater-40,000 BTU Kerosene w/T'stat Logo
636 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
