Question about Kenmore 22422 Top Load Washer
Kenmore elite top load will only fill half full of water
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    What is your model number? Kenmore makes several different types of top loaders. Some are direct-drive, some are belt driven, some use a rotor and stator.
    President:
  • 1,776 Answers
Check the water level switch. It's a diaphragm like device with a small plastic hose attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the tube and when it reaches a certain level, it activates the switch to shut off the water. Check the plastic tube for obstructions, pinching, or damage. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 09, 2009
3 Suggested Answers
miket756
  • 2702 Answers
SOURCE: Have a Kenmore Elite top loading machine and the
this sounds like the fill up censer is blocked up,,,its a cheep fix,,, its only a pipe that fills with water and at a set point it stops filling the washer, but if the pipe is partly blocked it throws its self into a wobely?? and thinks its over full so it starts to drain this water out
a good pear of lungs should blow any muck out this pipe
Posted on Jun 06, 2010
blueextc3221
  • 15935 Answers
SOURCE: MY KENMORE ELITE TOP LOAD FILL WATER AND AGITATES
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
I have a Kenmore Elite Oasis HE top load. The machine sounds like a thunder when it spins, and also a pond of water leaks on the floor.
Check your hoses for leaks or possibly the drain it's draining in is clogged or half clogged or too clogged to accept large amounts of water all at the same time. Not to sure bout the thunder part. Lol
Jun 13, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore top load washer (110-22642100) that will fill, agitate through entire wash cycle, but that's it.
HI THERE, IT SOUNDS AS IF YOUR PUMP IS BLOCKED, NOT WORKING OR SOMETHING MORE SERIOUS. START BY CHECKING THE PUMPS IS NOT BLOCKED, LOOSE CHANGE NORMALLY CAUSES THIS AND IS RELATIVELY EASY TO FIX.
Finding the pump on the Kenmore Elite top load washer is a fairly easy project that can be done in about a half hour. The Kenmore Elite is part of the GE line of appliances and shares many of the same interior mechanical parts and systems. The Kenmore Elite is a very streamlined exterior cabinetry design, but the interior can be accessed by removing just a few screws in order for you to locate the water pump.
things you'll need:
  • Screwdriver
    • 1
      Unplug the electrical cord of the Kenmore Elite top load washer from the electrical outlet before attempting to locate the pump.
    • 2
      Remove the end caps on the control console of the dryer by pressing in on the caps with your thumbs and pulling the caps forward to unfasten them.
    • 3
      Unfasten the screws on the ends of the control console in the front with a screwdriver and tilt the console back so that it rests on the back hinges.
    • 4
      Unplug the top lid switch from the rear of the lid that sits underneath the control console, pulling the switch straight up off the metal prongs by hand.
    • 5
      Pry the metal clips that sit on the top lid up with a screwdriver, lifting the clips to unlatch the top and pull the top lid cover off the washer base, setting it aside.
    • 6
      Locate the water pump at the base of the washing machine on the top of the motor shaft.
    • 7
    • take the cover off the pump and remove any blockage or debris.
thanks and good luck
iain
Read more: How to Find the Pump on a Kenmore Elite Top Load Washer ' eHow.com http://www.ehow.com/how_6304872_pump-elite-top-load-washer.html#ixzz1LQ4bdiFZ
May 04, 2011 | Kenmore Washing Machines
Have a Kenmore Elite top loading machine and the water starts to fill the drum and it empties out as it fills, so the drum only fills half way. No agitation or spin. Because it just sits there with the...
Jun 06, 2010 | Washing Machines
Smell coming from inside washing machine. Not musty.
This is a fairly common problem that often arises when the majority of washes are done with cold water.
Do what is called a maintenance wash where you set the machine to run with hot water and maximum fill of water. Add one half cup of baking soda and let it run through it's entire cycle with absolutely no clothes in it.
After it completes its full cycle check for that bad odor. If it is fully gone wonderful. If it is half as bad do a second maintenance wash.
If the maintenance wash doesnt seem to help at alll get back to me and I will make another recommendation.
May 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Water in Drum
replace fill valve under top left rear its bleeding throw it will fix that
Nov 12, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer filling up while turned off
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite quiet pak 4
its a inlet water supply error code check your cold fill line and fill screens at cold fill valve for block
Oct 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 22422 Top Load Washer Logo
64 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
