Receiver LED just turns off in 5 seconds
When I disconnect and connect the power cable the LED turns on and then after 5 seconds it turns off and then no other button works.
  • 476 Answers
Some tvs have a over voltage or over current circuit protection. this is built into the main circuit to avoid further damage to the tv set. Your tv probably has a switching mode power supply and it's shutting down probably due to an over current condition usually a shorted horizontal out transistor, that is why when you replug the ac cord you get the power light indicator come on for a few seconds then turns off. You may have to take the set in to a tech to diagnose the problem or get an idea on the repair cost.
Posted on Sep 09, 2009
Why is HDMI LED blinking and there is no power to the amplifier?
I assume that you are connecting your amp to a hi-def TV. Can you try out the TV stand-alone and see if it works? Perhaps there is a problem with the TV. The blinking light tells me that there is a HDMI related problem. What is connected to the HDMI? Check the cable and make sure both ends are connected properly. Disconnect the HDMI cable and see if the amp will turn on. Does it work? Do the lights on the amp come on? Give us some more details. Try the above and report back.
Jul 21, 2015 | Audio Players & Recorders
HP 2000-410US when turned on the power light button blinks 1 time every 5 seconds, nothing elas
1. Disconnect anything that is connected to your laptop. Usb Flash discs, External HDDs, Wireless Devices using dongles etc.
2. Make sure that your device does not receive any power i.e. Disconnect your ac cable, and remove battery from your laptop.
3. Hold down the power button for 5 seconds. This would drain remaining power from your laptop. But as the power cable and the battery are disconnected, you should not expect anything to happen.
4. Identify where your RAM is located under your laptop. Unscrew the cover off, then remove the RAM from your laptop. Replace the cover temporarily.
5. Flip over your laptop. Connect your power cable to the laptop, NOT THE BATTERY NEH! Then press the power button. Sometimes your laptop will make long beeps to let you know the RAM is not inserted in your laptop. But nothing will happen on your monitor because it needs RAM to show you something.
6. After those beeps, remove the power cable. Press the Power Button to drain remaining power on your laptop. Flip the Laptop and replace the RAM you have removed earlier.
7. Insert your power cable and try restarting your laptop and see what happens. I am sure by now you should have some response on your laptop monitor.
NB: While performing the above mentioned, remember PC or Laptop parts are delicate. Even static electricity can damage them. Thus before handling your laptop components, make sure you touch the wall or any large metal subject from time to time to discharge the static. Wear 100% cotton cloths as you are working on it. Bare feet even better to discharge the static
Jun 14, 2014 | Gateway MX8711 Notebook
Error code 0xc19a0035 hp model b210
1.Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button
7. Reinsert the cartridges, and then close any open doors on the product
8. If you receive a prompt to print a calibration page, do so.
9. If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
11. connect the printer directly to the walloutlet
12. Still issue is not resolved then do a reset on the printer : Disconnect the power cord from the back of the product.Wait for 20 seconds, and then press and hold # and 6 on the product Control Panel. Connect the power cord to the back of the product and then release the buttons when the product turns on.The product resets to factory defaults.
13. Issue not resolved then service the product
Oct 12, 2012 | HP Photosmart C7180 All-In-One InkJet...
Show error
E indicates an Error condition.
NOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon ( ). If your printer has a network or wireless connection, ignore this step.
Figure 1: Example USB connection (your product might not look exactly the same as this example)
2.Remove the cartridges from the product.
NOTE:If your printer does not have a display, wait until the cartridge lights blink. If the cartridge lights do not blink within a few minutes, skip to the next step.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.If you disconnected the USB cable, reconnect it to the rear of the product.
5.Wait 60 seconds.
If that doesn't work you can log on to HP.com/Support and Drivers.
Find your device and search the error codes listed.
You can also download a real good Utility, HP Print and Scan Doctor.
Apr 27, 2012 | HP DeskJet F380 All-In-One Printer
How to unlock motorola 3G A1000
Try this: Might work.
Connect the phone to a powered Clip. Phone display should give "USB cable connected" message.
Press UNLOCK button on the Clip.
Phone reloads. Within 5-10 seconds phone display gives "Waiting for PST" message.
Press 1 and 2 keys simultaneously in upper part of the handset. The phone enters boot mode (if you don't press these two keys during "Waiting for PST" message, the Clip will give red E/G led and you will have to start with step 1 again).
After 1 and 2 keys have been pressed E/G green led will blink and the phone reboots. Meanwhile E/G will give frequent green blinking and phone will turn on.
Do not disconnect cell phone from Smart-Clip while green led indicator blinks!
Green E/G led glows. The cell phone is unlocked.
Axxx/Exxx/Vxxx unlocking noteDon't unplug cable right after phone reboot, wait until E/G led stops blinking!
good luck.
kc
Mar 11, 2011 | Motorola Cell Phones
General printer error0x61011be9 Please help
This error means it is a hardware issue.
Solution one: Reset the product
1.
NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon ( ).
Figure 2: Example USB connection (your product might not look exactly the same as this example)
Description of disconnecting the USB cable.
2.
3.
Wait for the 'Insert Cartridges ' message to display on the control panel.
4.
5.
Wait 60 seconds.
6.
7.
8.
9.
Reconnect the USB cable to the rear of the product, and then try printing again.
Sep 10, 2010 | HP Photosmart D5460 InkJet Printer
My laptop wont start even though the light indicator in the charger is on
You may first try performing the steps mentioned below:
1) Connect the AC adapter into a known working AC outlet and to the DC jack on the notebook.
2) Verify the correct AC adapter is being used, and not a third-party replacement AC adapter.
3) Do not connect the AC adapter to a surge protector or extension cord.
4) If the DC jack on the computer is loose or damaged, the computer may require service.
5) Some AC adapters have a POWER LED indicator and can be confirmed as receiving power by ensuring the LED is lit. If the AC adapter is damaged, or the LED is not lit or continuously flickers when plugged into a working AC outlet, the adapter must be replaced.
6) Attempt to turn on the computer normally.
7) Press and hold the Power Switch for 5 seconds.
8) Remove the battery.
9) Disconnect the AC power adapter.
10) Press and hold the Power Switch for 5 seconds.
11) Connect the AC power adapter.
12) Attempt to turn on the computer.
NOTE: If the computer turns on without the battery, connect and charge the battery for 24 hours.
13) Disconnect all external devices that are connected to the computer.
14) Attempt to turn on the computer.
15) Remove any additional Random Access Memory (RAM) that was installed in the computer.
16) Attempt to turn on the computer.
17) The troubleshooting steps listed above should resolve your issue.
If you have completed all of the steps and the issue is not resolved, service may be required.
Jul 06, 2010 | Dell Latitude D600 Notebook
No powering on
Resolution:
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard.
Aug 24, 2009 | Dell Computers & Internet
Fix my receiver
irregular current is output from the speakers...turn off the receiver, check the speaker connections and turn on the power again.
Robert
Jun 28, 2008 | Sony STR-DA3000ES Receiver
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
