Question about Rl Flowmaster Rl Flo Master Proplus No Pump Sprayer, 2 Gallons
Need a new sprayer tip for the 2602 flow master pro plus
2 Suggested Answers
  • 961 Answers
SOURCE: I have the follwoing R.L.Flowmaster products: R.L.
They sell the sprayers and parts at Home Depot, Walmart and other places. I am providing a link for you to look at:
http://www.rlflomaster.com/wherebuy.htm
You can click on the store logos and pick out what you want and, they have an 800 number to check stock.
Posted on Jun 12, 2011
Won't prime
Try to trouble shoot the problem by doing this:
clogged filter(s)
you did not clean paint out of machine properly on last use
the packings are worn and need to be replaced- it wont hold or build pressure- also that sprayer has a max tip size of .15
Feb 18, 2014 | Wagner Tools & Hardware - Others
Having trouble getting a good spray pattern when I use thick latex
You have two choices to fix this problem: First thin the paint and/or add a conditioner like Floetrol to make the paint flow properly. Second, use a tip with a bigger opening. On sprayer tips there is a three digit number (.ABC). The first number (A) is one half the spray pattern size when held 12 inches from the wall. A two will give you a four inch pattern, five will give you a ten inch pattern, etc. The last two numbers (BC) are the oriface size. For latex you should be using at least a .017 or .019 tip but if the paint has to be very thick you may need a .021 or larger.
Jan 05, 2011 | Campbell Hausfeld Airless Spray Guns &...
I have lost my owners manual for my model 2602. Can I get that?
FUNNEL TOP SPRAYER MODELS 2601, 2602, 2602I, 2603, 1602: Operating Instructions ( http://rlflomaster.com/service/pdf/971-230.pdf )
Or, tired of browsing the web? Call us: 1-800-253-4642
Hope helps (remember to rate this).
Sep 30, 2010 | Rl Flomaster 2 Gallon Acid Resistant...
Bissell Pro Heat clear view plus...Flow indicator not turning...? Plugged? how to unplug
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
trstg
Nov 23, 2009 | Bissell 1699 ProHeat Clear View Upright...
Coleman 1600 pressure washer
Remove spray tip and clean with a paper clip, Check pump oil resevior and add 10w 30 pump oil if needed, also look for turn knob ,usually black with -+[plus /minus symbols ] and turn towards plus for extra pressure. May need new pistol/wand assembly and make sure hose is clear by seeing if water will run through hose freely and generously.
Thanks Kf1013 and please vote me a Fix Ya!!!
JJ505
Apr 13, 2009 | Coleman Pressure Washer PW0881800
Bissell carpet cleaner
The water sprayers on your Bissell are probably clogged. I had this problem this morning, myself, with my machine, about 15 months old. They get clogged up with mineral deposits. This is a *fairly* easy thing to fix yourself. Read all the way to the end before trying this fix.
Unplug the Bissell. Remove the water container pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your brushes when you press the water-and-soap trigger at the top of the Bissell's handle. These water sprayers tend to clog. See the metal spring running up the hose, behind each red water sprayer? As you squeeze the red plastic sides of one red water sprayer, use a screwdriver or other tool under the spring to wedge up the hose, to release the sprayer from its mount in the base. Stick a finger in the hole of the base of the Bissell where the sprayer was mounted and run it around the edges there including on the underside of the base to clean out any gunk you can find. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove the water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip down the hose so it compresses the spring and is no longer on the red plastic water sprayer. Now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the outer end of the red water sprayer in your mouth and seal your lips around it, and try blowing through it. You can't blow air through it, right? It's clogged. Open up a paper clip and push it back-and-forth through the small hole in the end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Now you have to put it back together. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Push the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
I had a problem when I fixed this on mine this morning, because when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. So try to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, I fixed this by removing the six screws on top of the Bissell base (the surface of which the water tank mounts on top of), and then pried it up. You can pull out the hose, reattach the red water sprayers to the hoses, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
There's something else you may need to do that can help get the water flowing. This one's easier. The Bissell uses pumps, which need to be primed. Sometimes an air pocket inside the machine keeps water from flowing. To prime the pumps, separate the two water tank pieces. Fill the base as usual and mount it on the Bissell without the top water tank piece. Plug the Bissell in and **turn it on**. (The Bissell must be running to do this.) Kneeling on the floor in front of the Bissell, reach up and press the soap and water release trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel a bit of suction. Lift your hand up and down a few times. Release the trigger and repeat a few times. Now that you've cleaned out your water sprayers and primed the Bissell's internal pumps, I'm hoping water will GUSH through your Bissell once again.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Empty all the water. Thoroughly rinse out both water container pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and blow all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and need more pampering than a vacuum cleaner, doesn't it??
Jan 24, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Rl Flowmaster Rl Flo Master Proplus No Pump Sprayer, 2 Gallons Logo
575 people viewed this question
Top Rl Flowmaster Garden Experts
andy just round the...
Level 1 Expert
Nick Olsen
Are you a Rl Flowmaster Garden Expert? Answer questions, earn points and help others
