Question about Garden
Carb needs adjustment running rough and shaking
Carb needs adjustment running rough and burning alot of gas . just purchased old owner said he rebult carb but couldnt get it adjusted rite.
  • 2 more comments
  • kratofile Sep 15, 2009
    simplicity 4212h 12.5 horse.. how do i adjust the carb correctly
  • rattosh51 May 11, 2010
    So what's the question? How to adjust it? Need what brand of mower and engine.
  • kevin846
    kevin846 May 11, 2010
    Could you supply make, model and engine numbers please?
  • Ben Dover May 11, 2010
    what model do you have?
  • 472 Answers
Sounds like the jet in the carb is bad or was not put in all the way
Posted on Oct 15, 2009
Runs rough at low rpms, won't idle correctly, runs normal above 4500 rpms
CARBS WEREN'T DONE CORRECTLY..MANY FINE LITTLE PASSAGES THAT ALL NEED TO BE CLEANED..
Feb 21, 2015 | GAS Motorcycles
2005 Harley Davidson 1200 Custom Sportster Stalls at Lights and Stop Signs
4700 not a lot of miles. This motorcycle needs to run. It will be rough until you can get the carb cleaned. I would keep doing what you have been doing for a while. After a couple hundred miles if it doesn't improve, you might want to consider having the Harley shop give it a good tune up. Check the plugs ...
May 28, 2013 | 2005 Harley Davidson XL 1200 C Sportster...
81 Seca XJ750 runs smooth until warm-then low end is rough and misfiring. What do I check first?
Something got missed in low speed circuit or incorrect pilot crew seetings, also check for intake leaks rubber carb joints.
its very critical to make sure the low speed circuit and jets are clean thoroughly.
Oct 26, 2012 | Motorcycles
Engine would not turn over unless I took out spark plug.I adjusted valves ,It cranks and runs now but smokes alot ,burning oil .what do I do?
sounds like the needle valve in the carb didn't seat and the gas drained into the engine see if the oil smells like gas as well
May 25, 2012 | Sears Garden
5500 watt generator won't start. Runs as long as starting fluid is applied. Checked gas flow, wire connections, on switch,took carb apart and checked float valve
With starting fluid, it runs, so this means spark and compression and valves closing properly. You mention gas flow, so gasolene is getting to the carb. This would then leave the problem being in the carb if indeed fuel is present at the carb. If you take apart the carb right now, is there fuel in the bowel? Or, remove the bottom screw on the carb, does gas flow out? Does it flow continuously or does it quit? This will indicate if the float valve is indeed opening. The only thing if you have fuel in the bowel and no start, even with the choke closed, is that the main jet must be plugged. Had the unit been sitting for quite a while with gasolene in it? Gas can "varnish" after a few months and this can cause plugging of the jets and other passages. How old is the gas in the unit? Old gas won't burn in the engine and this can also be a problem. Drain the tank, and carb, put some new gas in the unit and try it. You might have to take the carb apart again and use some carb cleaner to blow the **** out of all the carb passages. This should get it going again. Now, most important, when you get it running again, you need to adjust the engine speed so that you do not burn out any electrical equipment. If you have access to a frequency meter, plug it into the 120 volt outlet on the generator and adjust the speed so that the frequency with no load is 62 - 63 hz. This will allow the generator to drop to 60 hz under load. The adjustment is a 5/16 nut, right side of the upper engine, facing you.
Jan 31, 2011 | Briggs & Stratton Power Products 5,550...
Carburetor adjustment for Homelite 2 cycle engine The product doesn't start easy, and it does come to full throttle. If I run it on partial choke it runs fairly good, but it has been getting worse. Last...
I have the same problem with my MightyLite 26cc Blower/Vac. If it does start it runs rough on full choke and stalls on 1/2 choke or run. I've tried everything, fresh fuel, Seafoam, etc. Nothing works. First time I used it the exhaust burned a hole in my brand new Carhartt hooded sweatshirt. Best solution, throw it away, never buy another Homelite product and tell anyone who will listen what a piece of junk Homelite products are.
Sep 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Kohler motor starts then carb loads up with gas
If the engine is running rough then this could mean that you have weak spark or valve adjustment. When an engine runs rough it will not burn all the fuel, which will create excess fuel in the air cleaner housing. Also, make sure the the float is closing in the carberator.
May 01, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Rough running above idle
What maintenance have you done? Changed the plugs, air filter, oil, and such? I would get some sort of fuel treatment to run through the gas tank and carbs. This should clear up any partial clog in the fuel system.
Mar 11, 2009 | 2003 BMW R 1150 GS Adventure
Mustang 5.0 runs rough
well the first thing to check will be to make sure that the valves are adjusted properlyto me it sounds that the valves are not set right can you briefly explain whow you adjusted the valves in your engine?
Nov 11, 2008 | 1986 Ford Mustang
Garden Logo
271 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
