Question about Kenmore Oasis HE 27082 Top Load Washer
End Of cycle alert keeps beeping
The washer shoes no codes. The add a garment stays on, and the end of cycle alert keeps beeping all through the wash until the lid is raised and clothes emptied . The end of cycle loud ,soft, lights alternate as the alert keeps beeping through wash.
  • 5 more comments
  • TexAg Dec 13, 2007
    I am having the same problem - and advice
  • Anonymous Dec 15, 2007
    Exact same symptoms. 1 week after warrenty expired.
  • Anonymous Dec 22, 2007
    My washer started sounding a beep-beep every 10 seconds, in the middle of the night when it was not washing. We can' t get it to wash in any mode except to "wash the washer" mode. The Soil Level lights toggle constantly when you turn it on.
  • Anonymous Dec 23, 2007
    Mine just started beeping today. The dryer did it before warranty expired and the board was replaced. About a month after warranty went out it started again. Now the washer has started doing it. This isn't uncommon. Sears should do something about it.
  • Jon Y Jan 05, 2008
    My washer beeps about 16 times and the light alternates between loud and soft. Then, it stops for about the same length of time before it repeats this cycle. This continues the entire time the washer is powered on while washing or not. Also, at times, the add a Garment light is on while the lid lock light is on.
    Is this my control board?
  • Anonymous Mar 20, 2014
    I came home after a wash had finished, and the center column was still operating. I removed the clothes, even though the machine kept operating, despite the fact the lid was no longer locked, so I let it continue, thinking it would run through to the end of the cycle. However, it hasn't stopped since. I tried unplugging the machine for periods of time, and that didn't work, either.
  • Anonymous Mar 24, 2014
    by the end of a cycle the clothes are tangled together and I wonder if it is possible there is a garment stuck in the machine somewhere
  • 126 Answers
It sounds like your control board
Posted on Dec 14, 2007
My washer is showing a f32 ,f71 codes what does that mean
Sd Error Suds Detected (Stored Error Code F71) Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle. The suds reduction routine removes extra suds and assures proper rinsing of your garments. If the code remains and the wash cycle dial is ?ashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press START. Do not add detergent.
Ld Error Washer is taking too long to drain water from the washtub
(Stored Error Code F32) Check the following:
Is the drain hose or pump clogged?
Is the drain hose higher than 96" to reach the drainpipe?
Is the Drain Pump Running?
Is the pressure transducer hose kinked, disconnected, or punctured?
Press PAUSE/CANCEL to clear display.
Mar 02, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Water will not spin out. Code says 5d
The troubleshooting page in the owner's manual says: 5d "Sd" Suds Detected - Did you use regular detergent? Regular or hand-washing detergents are not recommended for this washer. Use only High Efficiency (HE) detergent. Did you add too much detergent? Always measure detergent. Follow detergent manufacturer's directions. If excessive suds are detected, the washer will display this code while running a suds reduction correction routine at the end of the wash cycle.The susds reduction routine removes extra suds and asures proper rinsing of your garments. If te code remains and the wash cycle dial is flashing after the recovery routine has stopped, re-select your desired cycle using cold water. Press start. Do not add detergent.
Dec 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Cabrio washer is showing a 5d error and not spinning or draining well. What is the problem?
Sep 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
Kenmore he2
Press and hold the "end of cycle" button for over 3 seconds, it will reset. You will hear a beep.
Dec 25, 2007 | Kenmore 46462 Front Load Washer
End of Cycle signal keeps beeping
Try pressing "rinse" + "pre-wash" buttons together for over 5 seconds. It will lock. Repeat again for 5 seconds, it will unlock.
Nov 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
771 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
