Question about Electrical Supplies
Will not run without choke being on ,when i plug in lights the engine starts to bogg down until it cut off
  • 313 Answers
You need to adjust the carburetor. It is getting to much gas. Turn the screw on the low side 1/8 turn.
If that is not your thing take it some where to get adjusted.
I hope i helped
Posted on Sep 09, 2009
I need help with my B/S Engine. Lack of power and black smoke coming from the exhaust.
If the plugs are ok and your engine is not smoking after starting and running ..Sounds like either of three things..all with the carburetor .First the carb has a adjustment screw for air/gas mixture on the side if the carb where it attaches to the engine..try this start the engine and at about half throttle..now adjust the screw clockwise until the engine starts to miss and bogg down then back the other way until it starts missing and bogging again. Then slowly adjust back and forth until you hear the engine run the smoothest..give it more throttle if it starts to run rough do the same procedure until you get the results you want..if it is the mixture problem this will take care of it..if this doesn't it it may be your fuel jet in the bowl dirty or the blow float sticking..if you are not familiar with carbs best to have a professional look at it..you can drop the bowl by removing the bottom bowl and clean it out...check to see if the float easly moves up and down..replace the bowl and go from there..worse scenario new or rebuilt carb...good luck..
Jun 07, 2014 | Briggs & Stratton Garden
My 2003 suzuki vl 800 misses real bad and it wont stay started without the choke being out. Could it be a spark plug or what
hi normaly this indicates a fuel problem, as the machine wont run properly without the choke you poss have a blocked jet in the carb or something, when you put the choke on the fuel is then pulled up, as the choke flap has closed of the air flow the natural thing is the vachume will pull up exsess fuel, this is fine until your engine becomes hot then the engine will start to run rough as a result of the overfueling, with respect of the spark plug if the engine runs the chances are the plug is fine, however overfueling will eventualy contaminate the plugs causing poor starting, with extreme care feel the exhaust pire from each cylinder where it comes out of the cylinder head, if it is hot then the spark plug is working just to reiterate you must ware a heat proof glove or wait till the engine has cooled down a bit before placing your hand near to the exhaust to avoid severe burns.
Nov 21, 2010 | 2003 Suzuki VL 800 Volusia
Runs first 30+ sec then bogs out/dies when throttle pressed
If still under warranty have it serviced (authorized dealer not Joe's lawn mower). There should not be a fee (paid by Husqvarna). There have been carburetor problems. If you adjust it your warranty will likely be void; Joe's small engine service just as likely to void any warranty. Are you using a fresh 40:1 fuel oil mix. The will not start with choke set is normal. Start procedure in your OM says listen for sputter and disengage choke. Almost all new saws have similar start procedure.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a Mcculloch 16in maccat 35cc chain saw
Does the chain turn freely by hand? Is it being oiled properly? Check the fuel filter, air cleaner, and muffler for plugging. Does 'feathering' the choke make any difference? If it helps, try turning the H jet needle CCW about 1/4 turn which should make it run more rich and 4-stroke until you are cutting which should immediately cause the engine to 2-stroke. Hope some of this helps!
Jul 21, 2010 | McCulloch Garden
My cousin rode my yz 125 down the block without pulling the choke up it cut off on him up the block he came back with the bike i tried to start it up and the engine wont begin to run at all this was the...
I don't think running the choke n had anything to do with the bike not starting again. I catch myself miles from home and find the choke still on. Just makes it run a little rich. If anything I would check the plug(s), they might have been fouled by the choke, just clean them up and see what happens. Check it out.
Jun 18, 2010 | 2003 Yamaha YZ 125
Cub cadet cuts out unless with full choke
Use a thin business card to set the module to flywheel magnets gap--rotate the magnets under the module poles, insert the card between the poles and magnets, loosen the module screws and allow the module to contact the magnets. Tighten the screws and rotate the wheel to remove the card. Rotate the wheel one turn and make sure the gap doesn't close up at any point. The spark plug gap is 0.020". Having to keep the choke closed to make it run implies that the main jet in the carburetor is plugged or if adjustable, the setting is too lean. Make sure the air cleaner is not plugged. Turn the jet screw CW to stop (lightly), then back out 1-1/2 turns CCW. If this helps, you may turn it either way until the engine runs smoothly without any choking required after warm-up. It it gets better, but still not running correctly, you may have to disassemble the carburetor and clean it with spray carburetor cleaner. Hope some of this helps!
May 28, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
MY chainsaw will start but boggs down when I squeeze the trigger then after a couple of times trying it wont even start it has a new spark plug what else could it be?
Check the fuel filter for plugging as well as the air cleaner and muffler. Make sure the choke control actually opens the butterfly plate in the carburetor when the choke is pushed off. Check the quality of the spark at the plug by laying the removed plug on engine metal (wire on plug) and pull through. The spark should be blue and snappy. Plug gap is 0.020". The insulator should be medium to light tan when the engine runs correctly. If still having problems, check the lower chamber diaphragm in the carburetor for being hard or cracked as it directly controls fuel flow through the carburetor. Hope this helps!
Apr 29, 2010 | Poulan Pro Chain Saw 46cc 20"
Will only run if choke is on i cleaned carb.i think it may b the primer bulb.iv tryed changing the lines didnt help
Check the fuel filter in the fuel tank for plugging. The primer bulb only affects starting. Make sure the muffler is not plugged. If these things look good, try turning the 'H' needle on the carburetor CCW about 1 turn. If this allows the engine to run without the choke, allow the engine to warm up. Then, open the throttle full on and turn the H needle back CW until the engine begins to speed-up, but is still 4-stroking. Correct adjustment is when the engine will smooth out as soon as it starts cutting, but 4-strokes when not cutting. Hope this helps!
Feb 19, 2010 | Garden
Electrical Supplies Logo
109 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
