Question about Whirlpool Dryers
I have an electric whirlpool dryer that stopped working suddenly. The model number is LER5600JQ0. I already disconnected and reconnected the dryer, checked the breaker, checked the start button and cycle button. Tested the door switch and the control panel. Light is on inside the drum. Stopped working after two loads this morning. Will not start.
  • 304 Answers
The problem you describe is usually caused by a thermal fuse intended to shut the dryer motor down and keep it off because of a problem with air flow within the dryer.
The following process will allow you to test the thermal fuse and replace it if you find it open.
Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail on electric dryers are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and, in some models, a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open. Replace the component that fails the continuity test.
Replacing the heater, if necessary, can be done by disconnecting the wires at the lower left of the heater can on right. There will be a screw on each side edge of the lower half of the can. Remove the two screws and pull off the back lower half of the heater can and reverse the above process to install the new heater.
The thermal fuse or high limit thermostat failure generally points to a reduction of air flow due to SOME blockage either inside the dryer or in the vent pipe leading out of the house. If you find either of these parts bad be sure to check the vents after replacing parts to ensure the same parts won't fail again.
Posted on Sep 09, 2009
Testimonial: "Thank you. That was it. Perfect. Had visions of a new motor or new machine. $10 part did the trick. Thank you, thank you."
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
GE Dryer model number dcvh515efww display not working
you could try removing the top of the unit, disconnect the display from the main wiring loom and reconnecting it, or try and buy a spare one and fit it.
Jul 17, 2012 | GE DCVH515EFWW Electric Dryer
Cabrio dryer end of cycle signal doesn't work
We are sorry to hear of the problem with your Whirlpool Dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your Dryer.
Apr 17, 2017 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My dryer works properply but doesn't heat
Disconnect power . Remove the panel from rear of dryer . On the long aluminum housing , close to the top , will be a small thermostat piece . Either check this piece for continuity or jump those 2 wires togather and reconnect the power . Check to see if dryer heats . If heats , pt # 279816 is the part you need . Both parts in the kit , must be replaced . If the dryer does not heat , disconnect power , reconnect the wires and check the element with an ohm meter . The wires for the element , are the 2 wires at the bottom of the housing . If no continuity , pt # 279838 is the element number .
Sep 06, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer will not start
should be on back behind rear panel on the duct assmebly
Aug 15, 2009 | Whirlpool Dryers
Plug dryer in wall wont start
The most obvious thing to me is that the cord may have been loosened or damaged by the move, or the terminals in the machine may have loosened. Either test the cord on your "new" machine, or replace it with a known "good" cord. Wait a minute....you already have one of those....
Try it, it may be the very thing!
Regards, --W/D--
Jul 28, 2009 | Whirlpool WED5100SQ Front-Load Electric...
Whirlpool Dryer Problems
contact the manufacturer. some parts might need to be replaced already.
Jul 13, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool Electric Dryer stop working
could be a bad motor , or the starter on the motor.?? if you can hear the motor running then go for a new belt..
Jun 13, 2008 | Dryers
Dryer does not spin
Usually if a dryer won't spin, I suggest checking the belt to make sure it isn't broke or even the motor burned out. If you post a model number for your dryer, I may be able to assist you further.
May 28, 2008 | Dryers
Dryers Logo
121 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
