Mirrored image on our tv
We replaced th pcb digital board in our tv and now everything is in mirrored image. It made the picture clear, as it was green before. Any suggestions?
    Champion:
  • 213 Answers
You have the yoke hook up worng trun the wire for the york. you see h and you see v trun the v a round the pix back to hom....
Posted on Sep 09, 2009
JVC HD 56FN97 No RED color
Does menu have any red? Yes = digital video bad; No is light engine bad.
Mar 31, 2014 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
Nikon D50 Just Quit Taking Pictures!
The imaging board is one of the two boards on the bottom of the camera. however, black images are usually a result of a bad image sensor itself (the 'CCD'), and the cost to replace that is far more than what your camera is now worth (if it is even still available)
Jun 02, 2012 | Nikon D50 Digital Camera with 18-55mm Lens
Our Phillips flat screen TV picture is split down the middle vertically. One side shows a mirror image of the other side, and then sometimes one side is a lighter shade than the other, when it is full...
This may be due to a faulty Timing Control board (TCON board). I had a similar problem with my Samsung LCD TV picture being split vertically down the middle. The image on both halves appeared fuzzy and in reverse (mirror) including the menus. I replaced the TCON board and the problem was resolved.
Aug 18, 2011 | Televison & Video
What is a pcb printed circuit board and where are they located on a th-50px80u plasma tv
A PCB Printed circuit board is every single board in your TV. That is what PCB stands for Printed Circuit Board.
Jul 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Sound, No picture
Try another video source. Try a digital source and an analog source. If you still get nothing, think about replacing the DG board and the H board.
Dec 19, 2009 | Panasonic TH-42PZ77U TV
Pictures are grainy - they had been nice and clear but even when you are looking at the display before you take the picture it has a grainy quality to it.
    This problem is related to the CCD imager. When CCD Imager start malfunction the image in LCD shows like that as you said. The good news is that CCD IMAGER is in free replacement according to th policy of the company.Contact any SONY SERVICE CENTRE nearby for free replacement of CCD IMAGER.
    Thanks for using fixya.
Oct 31, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
WD-62525 works fine but has hazy picture!
ISCABITTLE-TRY REMOVIG THE WHOLE FRONT SCREEN ASS'Y. AND CLEANING THE SMALL MIRROR INSIDE/BOTTOM YOU'LL SEE A HUGE DIFFERENCE-JOE TV
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 43H70
The Toshiba 43H70 has two RGB driver chips (p/n: STK392-110) responsible for aligning the RGB colors, one of them went bad. Instead of throwing the TV away, I decided to try and replace them, and fix the TV. I did, and it works great! I ordered two STK392-110?s online from Electronix.com, it cost about $18 including shipping. Each STK392-110 is about 2? in length, and 1.5? in height, and is an 18 pin device. The tools I used were all purchased at Radio Shack, and are: a soldering iron with a stand, solder, de-soldering tool, thermal grease, and a digital camera (yes, a digital camera). First, make sure the TV is unplugged! On the back of the TV, take the back wooden cover off. You?ll see a bunch of wires going everywhere, a power PCB board (probably brown), and a green PCB system board. The two STK392-110?s are on the green PCB system board attached to two big heatsinks. You will have to remove the green PCB system board to get to the two STK392-110?s and replace them, there?s no way around it. To remove the system board, you?ll have to remove the board with all the video jacks on it, and will have to disconnect all the wires going to the system board, as well as disconnect the power board from the system board. The power board and system board lie right next to each other, and are connected by two connectors. You have to be careful with those two connectors, and I used a small screwdriver, got it between the mating connector, and gently pried it open. It?s like an old mechanical switch, but instead of one contact, there are several. While taking everything apart, this is wear the digital camera comes in, take a picture of everything you disconnect and remove, and play the pictures backward so you know how and where to put everything back together. The system board is held down by several screws that will need to be removed. Once the system board is removed, you can see the two STK392-110 driver chips, however, you will have to remove several vertical boards and heatsinks to get to them freely. The STK392-110?s are attached to two heatsinks by two screws each. The heatsinks are soldered on the system board, so you?ll have to desolder them to remove them. Once you have them removed, Now that the old STK392-110?s are freely accessible, go ahead and use a pair of wire cutters, and cut them off at the leads (the 18 pins). Now desolder the 36 pins left in the board. Use the desoldering tool to get as much solder out of each hole so you can easily put the new STK392-110?s back in. (Make sure you put them in the same way as the old ones!) Put the two STK392-110?s into the holes, put the thermal grease on the metal side of the STK392-110, then attach the heatsinks to them, line up the two mounting screws that hold the STK392-110 to the heatsink, and start soldering everything back together. Make sure you use enough thermal grease between the heatsinks and the STK392-110?s, too much is better than not enough. It will look like the 18 pins are all connected together on the PCB system board, but they are not, make sure you individually solder each of them to the PCB board, and do not let solder from one pin touch solder from the pin next to it!! Use the digital pictures you took and play them backwards so you can put your TV back together correctly. Attach your TV cable to the TV, plug it in, and use the remote to turn it on (stand back just in case you crossed some wires), it should work, and the picture should be perfect.
Aug 13, 2007 | Toshiba 43H70 43" Rear Projection...
Convergence
Remove the back containing the mirror and look into the projection lenses either at low brightness or with the tv turned off using a flashlight. Look for the fluid posibly being murky (should be clear). If this is the case, to replace the fluid: 1. Unplug the TV. 2. Remove the Picture Tube with Lens Assembly that has bad fluid 3. Find the drain plug 4. Drain the fluid in the sink. 5. Take a picture from all angles to review later. 6. Dissassemble the fluid chamber from the picture tube and clean the front glass and chamber. 7. Reassemble and fill chamber with mineral oil (laxitive found in a drug store). 8. Repeat the proceedure until all three CRT images are clear. 9. Use the centering magnets located above the CRT PCB's to get the convergence in the center. 10. Use the convergence proceedure from the tv menu to complete.
Nov 26, 2006 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
