Question about Craftsman Garden
Flat front tire need to remove from craftsman 13.5hp ohv riding mower
  • 389 Answers
Remove the plastic dust cover, remove the E clip holding it on the spindle, remove the spacer/thrust washer, slide wheel and tire of
Posted on Sep 14, 2009
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
How to remove the front wheel on a victa NXT23/46 ride on mower
Graeme, usually you remove the rubber/plastic axle/hub cap, jack mower up and secure from falling, next remove retaing clip( C clip, cotter pin, etc), and washer, slide wheel off. Check the attached links,instruction and guides, could not find your model, Good luck
Changing Front Tire on The Craftsman
Removing Wheel from Riding Mower
http://support.mtdproducts.com/app/answers/detail/a_id/203/~/wheel-removal---riding-mower
Apr 24, 2016 | Garden
How do I take a front tire off a craftsman lawn tractor
some have a plastic hub cap that you pry off then either a cotter pin or a c clip that needs to be removed .
Aug 26, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hello, my craftsman 13.5hp ohv rider will not start. The left front tire deflated here 1 week ago, so I left the mower in the back yard for 2 nights, which happened to be very cold with frost. After fixing...
Remove battery and bring inside. Let it set for a few hours to warm up, it may be partially frozen. If you have a battery charger, after it has warmed up fully, charge it at a slow rate (1A) overnight. Put it back in the mower and try again. If still nothing, the battery may be ruined.
Oct 09, 2010 | Craftsman 1 Bin Grass Bagger
Craftsman Ride-on hard start, loss of power
you have to get piston to top dead center, there should be 4 thousandths of clearance between rocker and valve on both valves.
use two wrenches to tighen
Sep 02, 2009 | Craftsman Garden
Craftsman 30'' mower front tire off rim can't put back on
hello...is the tire loose but still on the rim...the sidewalls no longer engage the rim tight to hold air but still aroung the rim loose....If that's the case, get a jack, can of fix a flat, and a small ratcheting hold down strap.....jact the tire off the ground.....wrap the strap around the tire and ratchet it tight to get the beads of the tire to touch the rim....then commect the fix a flat or, if you have ,,,air from compressor to inflate the tire,,,,might have to work it a little to get the tire to reseat on the rim....this should work for you....once the tire is seated on the rim....stop inflating the tire until you remove the strap or you migh have a problem getting it to release from the tire if fully inflated....
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I would like to change the front tires lawn mower
Remove the wheel from the mower.
Let all the air out
Lay the tire flat
Push on the tire to release the grasp on the diameter of the rim (use a malet if ou need to)
Apply soapy water to the tire and rim
Insert a standard screwdriver between the tire and rim and pry the tire over the rim in one spot
Then work the screwdriver around the rim, pulling the rest of the tire up and over as you
go
Repeat the last step for the other side of the tire, same side of the rim though!
Viola, there you have it. Shade tree mechanic at it best. And NO labor cost$$$!!!!!
Mar 22, 2009 | Swisher 52" 20 Hp Riding Lawnmower #Zt2052
Can not remove axle cover,
Hi, easy fix you have to pry the cover off. you can use a screw driver, or a pry bar.
Nov 22, 2008 | Craftsman Garden
Garden Logo
218 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
