Question about Nintendo Wii Console
Will not turn on. after a power outage.
Will not turn on.after apower outage.
  • 6,784 Answers
HI. this will happen during most outages. there is a fuse located inside the power supply device that is used to power your unit. simply remove the cover off the power supply box, and replace the fuse inside. this will correct the issue.
***((Now, if the fuse is OK, and not harmed, this will confirm that the power supply has failed. It should be replaced in this case))
Posted on Sep 09, 2009
Power outage
its gone when themachine is turned off from the power outage, have them resend it
Apr 15, 2014 | Brother IntelliFAX 560 Plain Paper Fax
True freezer
check the condenser and freon
Aug 18, 2008 | True Freezers
I had apower outage while playing the game and now some of omy chips are missing
Your poker account has been disabled.
If you believe this is an error, please contact customer support to request reactivation.
Nov 22, 2012 | Evermoremedia DoubleDown Casino
Toshiba led tv wont turn on
Is your power light blinking,If it is it went in to what they call the protection mode,Apower surge will cauase them to do that, If that has happen ,What they call the power board has to be replaced.
Oct 10, 2012 | Televison & Video
I have a sanyo 26 " lcd hdtv and we had apower
hi you will need first to isolate where the problem might be so try to plug other unit or device in your power surge like a dvd player. if it is work your lcd tv have problem now how are you going to fix your tv, use a philip screw driver and open the back cover to gain access the internal part. since doesn't turn on check the power supply first which is the main source of supply of all the board. replace blown fuse and other defective part. bulged capacitor will not work good replace it use the panasonic brand atleast 105c ratings it is effective. thanks hope will help you to fix the problem.
Jun 19, 2011 | Sanyo Televison & Video
1 have a xerox copier model XD120F Had apower outage when copier cam back on screen is showing a H4 and not powering up thanks Joe
Hello
Since the problem occured after a power outage,you should try resetting the H code.
Press CLEAR, EXPOSURE MODE, CLEAR, EXPOSURE MODE. The display should go blank. Then enter 14 with the copy count keys and press START. If the machine does not turn off and back on by itself - then turn it Off and back on. See if the H code should vanish and your copier should work well.
Apr 17, 2011 | Office Equipment & Supplies
We had apower outage and afterward the computer will not turn on.
if u have a power supply that has an on/off switch on the back of it turn it off for about 30 sec. then back on then try to turn the computer back on.If that doesnt then you will have to clear the bios.
Nov 27, 2010 | Computers & Internet
Power outage and freezer is now flashing "e" on display
look on the inside of the toe kick at front bottom or just inside front bottom and you will find a tech sheet that will give you error codes.
Jul 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
WE HAD POWER OUTAGE/NOW WE HAVE THE LETTER A--WONT GO AWAY
Your machine is set to "Announce" instead of "Answer" mode. The announce mode merely plays an outgoing message but does not record any incoming messages.
Since you neglected to specify the model of your VTech 5.8GHz cordless system I can only suggest you enter it into the search box here to download a copy of the manual to learn how to switch modes.
Mar 04, 2009 | Vtech 5.8GHz Expandable Cordless Phone...
I had a power outage!
Hi there!
Power outages and lightning are the main causes of Electronic failure. It has obviously affected your TV and will need to be seen to by a repair technician if you are not skilled to do so. Regards and good luck, JUS004
Apr 01, 2008 | Apex Digital AT2002S 20" TV
Nintendo Wii Console Logo
209 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
